The image from Nvidia works fine for the Jetson Nano, no problems there. I then wanted to use a different OS, and burned that to the sd card but then the Jetson was stuck at the Nvidia logo. I then used the serial to view the output (attached). It looks like for some reason it can not read the boot file with this particular OS.
Someone else I know tried the same image, on their Jetson Nano and it worked fine.
Re-burning the Nvidia image back onto the sd card and again everything starts fine, so I don’t think it is the sd card failing? Also not an issue with the different OS I am trying to run as that works on someone else’s nano.
The different OS I am trying is the BalenaOS.
Thank you.
boot_serial (2).txt (21.3 KB)
