My development device does not detect mouse and keyboard
which does not let me operate the operating system.
I want to know if I should suddenly put an additional jumper for the usb port to work or change to another operating system
It is possible the Jetson itself is flashed with a different version of software than what the SD card is flashed with. Dev kits contain QSPI memory, and you will probably need to flash the Jetson itself with the same release of software (via JetPack/SDK Manager) for which the SD card is designed to work with.
If you want to still troubleshoot, then you are advised to get a USB serial UART cable and get a boot log (which also can allow end user setup without the local keyboard). See:
https://www.jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
