I want to consult that I installed ds5.0 on jetson nano, and run the “nvdsanalytics-test” plugin, why the image is very stuck, frame by frame ?
Checking internally, will back to you once done.
it works fine from our side. can you provide details of which app you are working and set qos = 0 on sink component. The clocks should be boosted and it has been provided in documentation (Jetson clocks utility)
Hi, I’m running deepstream-nvdsanalytics-test app and it’s quite slow. Here’s my new issue:
The deepstream-nvdsanalytics-test frame dropped problem is very serious
I see your issue solved in topic you mentioned.
