We are facing this issue with 4 boards, other 10+ boards are fine, unfortunately the board is at clients place and they have only on module at the moment. lets see if we can try your advice.
Suspected on BSP since we are able to see the nvidia logo and console logs. you feel even if it boots till this there are chances of hardware issue? we have checked voltage etc
I think you can give a more precise terms of “boards” here. What do you mean boards? A module+ carrier ? or just the carrier? What is changed when you says “another board”
Since most of them are your custom board, I cannot guarantee the quality for each of them.
Also, just a suggestion that might not help. Can you try to resolve your gpio error? This panic appears in both your working case and failure case. Should prevent such error.
And you can try to disable tegra_cec in the device tree and see if this prevents panic. But your first error log in this topic does not have cec error and it still crashed. Thus, I doubt it.
we have one single nano module and multiple carrier boards. board here is just carrier board. when I say another board, same setup + same module and different carrier board. only carrier board is changed.
