Hi, I am using Jetson Nano Oring to do some data processing and machine learning. While I need to install the CProfileV. After pip install it in virtural environment, and diable the GUI and reboot it again.
But then I found, I cannot connect to it throug SSH, and cannot even find it through serial after connect it through typeC to my mac. Since I diabled the GUI, I cannot even see what happened through GUI.
I’ve also try to reset it through pin hearder (connect 9 and 10), but no thing happend. Now I feel like it a little bit hot, but the fan does not rotate, even the PWR grenn light is on.
Does anyone have any solution about it? Appreciate very much!!!
And Also, there is a wanning: test key is used and then the screen will shunt down. And I try to entery the recorver mode (connet pin 9 to pin 10 and then pulg power input), but the SDK Manager still cannot detect a board.
I even try to download nano orin image to a new sd card and insert to it. No thing changed. Is it a hardware issue? >_< really do not know what I should do
