Jetson nano orin is not booting up but fan is working
Using the microsd installation guide, I made it all the way to updating the firrmware but now when I power it on I get no signal from the monitor, but the fan is still running. After I ran
sudo apt-get install nvidia-l4t-jetson-orin-nano-qspi-updater
I shut off the jetson, removed the sd card, flashed the 6.x version and booted it up and got this error
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Based on your image provided, the uefi version still in older version.
Could you point out which step you stuck in ?
I was stuck when booting after flashing the memory card with latest image.But it was solved when i did it using SSD
