Jetson Nano Orin, stuck with SSH
For the new Jetson Nano Orin that I recently got, I burned the SSD with the latest image. The board is booting up. With an additional monitor/keyboard/Mouse, I am able to login to the the Linux environment. Board is connected to my WiFi and everything seems normal. I am trying to SSH from my Macbook to Jetson via USB cable/port. But I am getting this very strange long message.
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ED25519 key sent by the remote host is
SHA256:3rLPmg7Jiwwr5NSWI3lJbfVghUR3N4Retspc4HG+KRg.
Please contact your system administrator.
Add correct host key in /Users/navidkhajouei/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /Users/navidkhajouei/.ssh/known_hosts:3
Host key for 192.168.55.1 has changed and you have requested strict checking.
Host key verification failed.
Any suggestions how to resolve?
Please execute the command and try to login again:
$ ssh-keygen -f /Users/navidkhajouei/.ssh/known_hosts -R 192.168.55.1
I will give this a try tomorrow when I am back in office. Meanwhile I realized something. My username on Jetson is “navid” and the command i entered on my Macbook:
SSH navid@192.168.55.1
The message below is strange because “navidkhajouei” is actually my MacBook (host laptop) user name:
So I am confused what it’s talking about.
If you ssh to any host it remembers some of the details. If any detail changes, you are alerted with this. Some examples:
  • If you use a named address, and the DNS resolves to a new or different dotted-decimal address, then you get a warning.
  • The host itself has a key. This key is randomly generated most of the time during install or first boot. If that key changes, then you are alerted. An example of a change (depending on how it is done) you might see is if you (A) reinstall or flash again, or (B) replace a major system component (sometimes).
  • If you’ve used a dotted-decimal address in the past, or a named address, but switch which one you use, then you will get a warning (in one case it might be a change warning, but in another case it might be considered a “new” connection).
It is quite common to get such a warning if you re-flash a system. One thing I do prior to flashing, if the system has been used on a network before, is to copy some of the original content into the “Linux_for_Tegra/rootfs/” content. Examples would be:
  • Any ssh keys or setup for the host.
  • Any user accounts I plan to use, including home directory. This indirectly implies saving the “~/.ssh/” content.
  • Any “/etc/hosts” aliases.
Note that I do the above even when I don’t clone. A good reason for this instead of cloning is the case of upgrading from one release to another when you cannot use a clone.
Thanks so much. This worked for me.
