Hi All,
We have been using the Jetson Orin Nano Dev Kit for R&D purposes without any issues until recently when the USB 3.0 ports suddenly stopped functioning. Currently, there is no output voltage from any of the USB ports.
Upon investigating the AP22811AW5-7 chip, we observed the following voltages with respect to the ground pin:
- PIN1 (OUTPUT): 0 V
- PIN5 (IN): 5 V
- PIN3 (HUB_DSP12_OCP): 3.3 V
- PIN4 (HUB_DSP12_PWR_EN): 0 V
lsusb -t -v output:
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 3: Dev 2, If 0, Class=Wireless, Driver=rtk_btusb, 12M
ID 13d3:3549 IMC Networks
|__ Port 3: Dev 2, If 1, Class=Wireless, Driver=rtk_btusb, 12M
also attached dmesg file for your reference.
dmesg.txt (57.9 KB)
Any guidance on resolving this issue would be greatly appreciated.
