I am using a jetson nano, where my application needs to encode and decode video and also encode audio using gstreamer and utilizing gpio.
Do I require the packages like cuda tool kit and other large packages for the above tasks to perform? Since the storage in the emmc is limited.
Thanks in advanced
If you don’t need CUDA or TensorRT, you should not need to install the packages.
May also remove the packages:
$ sudo apt remove --purge thunderbird* libreoffice* chromium*
system
Closed
5
