Hi! We have two Jetson Nano production modules with the same problem. After starting the flash process, both modules get an error when erasing sdmmc3. Can I do something in this case?
uart_out.txt (7.9 KB)
What is your flash command and what kind of board are you using now?
Is it a NV developer kit or some custom carrier boards?
Thank you for responding. My flash commands:
sudo ./flash.sh jetson-nano-emmc mmcblk0p1
or
sudo ./flash.sh -r jetson-nano-emmc mmcblk0p1
We are using Jetson Nano P3448-0002-B02 module and our custom carrier board. But it seems to me that the problem is not with our board. After that, 3 exactly the same modules were successfully flashed and tested on this board. Everything is fine.
Do you have devkit to test the problematic modules?
Unfortunately, we do not have a development kit for Nano B modules.
Please try to get one and use that to validate these modules.
I will receive it only in a month, can I do something else while waiting for the dev kit?
