I am trying to install packages in the jetson nano production module, but I got disk full error
when I run this command df -h,
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 14G 13G 22M 100% /
I have 64GB memory card, is it possible to install the packages in the sd card, and use as it is and how should we achieve or handle this disk full error
You can easily use the SD card like this, but first you need enough control to free some space before you start. Are you able to log in and remove any temporary or unused files? If not, then try via serial console: https://www.jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
When ready just ask, and details on using the SD card can be added. When you do reply add any information on current SD card partitions if you plan to use those, or note if you want to reformat.
