Jetson nano pwm pin to irf520 mosfet driver
Hi team,
I am trying to control speed of motor with driver board( IRF520 MOSFET) with pwm pin of Jetson nano.When i connect 3.3v directly to driver board,things are working fine and motor is rotating.When I connect pwm pin to driver board it is not rotating.PWM pin is generating pulses of 3.3v but it is not able to run the driver.Is it something to do with io pins?
Moving to Jetson Nano forum.
hello Raksha_A,
please refer to below discussion threads, which related-to Nano PWM,
thanks
