Jetson nano python apps yolo object detected source id or name
I am using python multi stream imagedata example to run my custom yolo model, when i am using one source i am able to get meta data such as object id and confidence. but when i am using 2 sources how can i know from which source the object is detected. something like a source id.
so i found the solution. we need to add
sourceidd = frame_meta.source_id
YES. You can find some information in this document:
Yes, I referred the same. thanks
