For sudo dmesg:
robotika@nano:~$ sudo dmesg
[sudo] password for robotika:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.299-tegra (buildbrain@mobile-u64-5333-d8000) (g cc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065 c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Nov 22 09:24:39 P ST 2022
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nv idia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id n vidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible i d nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M secti on=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvf s=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debu g_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_ scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype= ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.e n_boot_part_access=1 quiet root=/dev/sda1 rw rootwait rootfstype=ext4 console=tt yS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_acc ess=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29804(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes )
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568328K/4159488K available (15422K kernel code, 2970K rw data, 6712K rodata, 8640K init, 614K bss, 116024K reserved, 475136K cma-reserved )
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 M B)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 G B)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f90000 ( 15424 K B)
[ 0.000000] .rodata : 0xffffff8008f90000 - 0xffffff8009630000 ( 6784 K B)
[ 0.000000] .init : 0xffffff8009630000 - 0xffffff8009ea0000 ( 8640 K B)
[ 0.000000] .data : 0xffffff8009ea0000 - 0xffffff800a186808 ( 2971 K B)
[ 0.000000] .bss : 0xffffff800a186808 - 0xffffff800a22032c ( 615 K B)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 K B)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 M B)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 G B maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 M B actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 M B)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /inte rrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (ph ys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980 46511078ns
[ 0.001725] Console: colour dummy device 80x25
[ 0.001736] console [tty0] enabled
[ 0.001741] bootconsole [uart8250] disabled
[ 0.001763] kmemleak: Kernel memory leak detector disabled
[ 0.001781] Calibrating delay loop (skipped), value calculated using timer fr equency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001792] pid_max: default: 32768 minimum: 301
[ 0.002235] Security Framework initialized
[ 0.002452] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002460] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003569] ftrace: allocating 47250 entries in 185 pages
[ 0.172280] sched-energy: CPU device node has no sched-energy-costs
[ 0.172313] ASID allocator initialised with 65536 entries
[ 0.212062] tegra-id: chipid=22117.
[ 0.212074] tegra-id: opt_subrevision=0.
[ 0.212091] Tegra Speedo/IDDQ fuse revision 4
[ 0.212096] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.212101] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.212107] Tegra: CPU Speedo Value 2029, SoC Speedo Value 1916, GPU Speedo V alue 2015
[ 0.212111] Tegra: CPU IDDQ Value 1496, SoC IDDQ Value 1716, GPU IDDQ Value 2 025
[ 0.212130] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.212150] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/ arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel- dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.212157] DTB Build time: Nov 22 2022 09:26:48
[ 0.261076] CPU1: Booted secondary processor [411fd071]
[ 0.292969] CPU2: Booted secondary processor [411fd071]
[ 0.324954] CPU3: Booted secondary processor [411fd071]
[ 0.325042] Brought up 4 CPUs
[ 0.325047] SMP: Total of 4 processors activated.
[ 0.325055] CPU features: detected feature: 32-bit EL0 Support
[ 0.325308] CPU: All CPU(s) started at EL2
[ 0.325325] alternatives: patching kernel code
[ 0.333485] devtmpfs: initialized
[ 0.370980] Initilizing CustomIPI irq domain
[ 0.371282] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.371303] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.381886] pinctrl core: initialized pinctrl subsystem
[ 0.382462] OS set in device tree is not L4T.
[ 0.382885] regulator-dummy: no parameters
[ 0.383147] Initializing plugin-manager
[ 0.383300] Plugin module not found
[ 0.383497] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.383992] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.384416] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.385181] node /plugin-manager/fragement@7 match with odm-data enable-pmic- wdt
[ 0.385393] node /plugin-manager/fragement@8 match with odm-data enable-pmic- wdt
[ 0.386003] node /plugin-manager/fragement@13 match with board >=3448-0002-30 0
[ 0.389516] NET: Registered protocol family 16
[ 0.390899] pstore: using zlib compression
[ 0.390941] console [pstore-1] enabled
[ 0.390945] pstore: Registered ramoops as persistent store backend
[ 0.390950] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.405095] cpuidle: using governor menu
[ 0.409192] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.410843] vdso: 2 pages (1 code @ ffffff8008f97000, 1 data @ ffffff8009ea40 00)
[ 0.410866] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413536] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomi c allocations
[ 0.415816] Serial: AMBA PL011 UART driver
[ 0.416362] tegra_powergate_init: DONE
[ 0.416379] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/ arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel- dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.416385] DTB Build time: Nov 22 2022 09:26:48
[ 0.418249] Tegra reboot handler registered.
[ 0.422717] iommu: Adding device tegra-carveouts to group 0
[ 0.422848] platform tegra-carveouts: domain=ffffffc0f94333d8 allocates as[0] =ffffffc0f94240a8
[ 0.423191] iommu: Adding device smmu_test to group 1
[ 0.423245] platform smmu_test: domain=ffffffc0f9433618 allocates as[0]=fffff fc0f9424110
[ 0.424052] mc: mapped MMIO address: 0xffffff8008041000 -> 0x70019000
[ 0.424107] mc: mapped MMIO address: 0xffffff8008067000 -> 0x7001c000
[ 0.424164] mc: mapped MMIO address: 0xffffff800807b000 -> 0x7001d000
[ 0.424174] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.424192] mc-err: mcerr ops are set to t21x
[ 0.434749] iommu: Adding device 70090000.xusb to group 2
[ 0.435025] iommu: Adding device 70006000.serial to group 3
[ 0.435083] platform 70006000.serial: domain=ffffffc0f943ccd8 allocates as[0] =ffffffc0f9424178
[ 0.435508] iommu: Adding device 70006040.serial to group 4
[ 0.435761] iommu: Adding device 70006200.serial to group 5
[ 0.435954] iommu: Adding device sound to group 6
[ 0.436004] platform sound: domain=ffffffc0f94bf258 allocates as[0]=ffffffc0f 94241e0
[ 0.436558] iommu: Adding device 7000d400.spi to group 7
[ 0.436860] iommu: Adding device 7000d600.spi to group 8
[ 0.437237] iommu: Adding device 50000000.host1x to group 9
[ 0.437508] iommu: Adding device 54080000.vi to group 10
[ 0.437900] iommu: Adding device 54600000.isp to group 11
[ 0.438155] iommu: Adding device 54680000.isp to group 12
[ 0.438451] iommu: Adding device tegradc.0 to group 13
[ 0.438502] platform tegradc.0: domain=ffffffc0f94d5018 allocates as[0]=fffff fc0f9424248
[ 0.439015] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.439339] iommu: Adding device tegradc.1 to group 14
[ 0.439390] platform tegradc.1: domain=ffffffc0f94d5258 allocates as[0]=fffff fc0f94242b0
[ 0.439890] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.440150] iommu: Adding device 54340000.vic to group 15
[ 0.440350] iommu: Adding device 544c0000.nvenc to group 16
[ 0.440545] iommu: Adding device 54500000.tsec to group 17
[ 0.440743] iommu: Adding device 54100000.tsecb to group 18
[ 0.440939] iommu: Adding device 54480000.nvdec to group 19
[ 0.441168] iommu: Adding device 54380000.nvjpg to group 20
[ 0.442209] iommu: Adding device 546c0000.i2c to group 21
[ 0.442538] iommu: Adding device 57000000.gpu to group 22
[ 0.442609] platform 57000000.gpu: domain=ffffffc0f9524258 allocates as[0]=ff ffffc0f9424318
[ 0.442648] platform 57000000.gpu: domain=ffffffc0f9524258 allocates as[1]=ff ffffc0f9424380
[ 0.442684] platform 57000000.gpu: domain=ffffffc0f9524258 allocates as[2]=ff ffffc0f94243e8
[ 0.442721] platform 57000000.gpu: domain=ffffffc0f9524258 allocates as[3]=ff ffffc0f9424450
[ 0.443551] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency t hermal reset disabled.
[ 0.443562] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.443572] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.443577] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.443582] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.493262] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registere d
[ 0.493272] tegra-pmc: Clear bootloader IO dpd settings
[ 0.493295] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.493356] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.493654] iommu: Adding device 70012000.se to group 23
[ 0.494232] iommu: Adding device 1003000.pcie to group 24
[ 0.494282] platform 1003000.pcie: domain=ffffffc0f95249d8 allocates as[0]=ff ffffc0f94244b8
[ 0.494708] iommu: Adding device 7000c000.i2c to group 25
[ 0.494976] iommu: Adding device 7000c400.i2c to group 26
[ 0.495225] iommu: Adding device 7000c500.i2c to group 27
[ 0.495477] iommu: Adding device 7000c700.i2c to group 28
[ 0.495722] iommu: Adding device 7000d000.i2c to group 29
[ 0.496018] iommu: Adding device 7000d100.i2c to group 30
[ 0.496279] iommu: Adding device sdhci-tegra.3 to group 31
[ 0.496333] platform sdhci-tegra.3: domain=ffffffc0f9532558 allocates as[0]=f fffffc0f9424520
[ 0.497205] iommu: Adding device 700d0000.xudc to group 32
[ 0.500396] vdd-ac-bat: 5000 mV
[ 0.500752] vdd-5v0-sys: 5000 mV
[ 0.501440] vdd-5v0-hdmi: 5000 mV
[ 0.501878] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.502127] vdd-1v8-sys: 1800 mV
[ 0.502496] vdd-fan: 5000 mV
[ 0.502715] vdd-fan: supplied by vdd-5v0-sys
[ 0.502935] vdd-usb-vbus: 5000 mV
[ 0.503176] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.503520] vdd-usb-vbus2: 5000 mV
[ 0.533885] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.535980] gpio gpiochip0: gpio-line-names specifies 240 line names but ther e are 256 lines on the chip
[ 0.539101] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.539134] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.539154] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.539520] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip 0 (tegra-gpio)
[ 0.547364] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.547697] SCSI subsystem initialized
[ 0.547875] libata version 3.00 loaded.
[ 0.548111] usbcore: registered new interface driver usbfs
[ 0.548160] usbcore: registered new interface driver hub
[ 0.548202] usbcore: registered new device driver usb
[ 0.552065] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.557098] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.558034] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.558130] random: fast init done
[ 0.561097] vdd-ddr-1v1: 1150 mV
[ 0.565086] vdd-pre-reg-1v35: 1350 mV
[ 0.568985] vdd-1v8: 1800 mV
[ 0.572242] avdd-sys-1v2: 1200 mV
[ 0.576243] vdd-pex-1v0: 1050 mV
[ 0.576904] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.577470] max77620-ldo3: at 3100 mV
[ 0.580245] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.580825] max77620-ldo5: at 3100 mV
[ 0.584238] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.588239] avdd-1v05-pll: 1050 mV
[ 0.592237] avdd-io-hdmi-dp: 1050 mV
[ 0.594800] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.595101] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpioch ip1 (max77620-gpio)
[ 0.595401] max77620 4-003c: max77620 probe successful
[ 0.598289] media: Linux media interface: v0.10
[ 0.598339] Linux video capture interface: v2.00
[ 0.599279] pps_core: LinuxPPS API ver. 1 registered
[ 0.599284] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.599300] PTP clock support registered
[ 0.602384] tegra210-emc 7001b000.external-memory-controller: validated EMC D FS table
[ 0.603205] Advanced Linux Sound Architecture Driver Initialized.
[ 0.603839] Bluetooth: Core ver 2.22
[ 0.603885] NET: Registered protocol family 31
[ 0.603888] Bluetooth: HCI device and connection manager initialized
[ 0.603903] Bluetooth: HCI socket layer initialized
[ 0.603911] Bluetooth: L2CAP socket layer initialized
[ 0.603944] Bluetooth: SCO socket layer initialized
[ 0.605749] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.605765] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.605805] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.605818] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.609011] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering pr obe
[ 0.610233] vdd-3v3-sys: 3300 mV
[ 0.610572] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.610619] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.612327] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.612756] vdd-3v3-sd: 3300 mV
[ 0.613155] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.613728] avdd-io-edp-1v05: 1050 mV
[ 0.614075] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.614231] vdd-usb-hub-en: 5000 mV
[ 0.614607] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.615674] camchar: rtcpu character device driver loaded
[ 0.616418] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.617840] clocksource: Switched to clocksource arch_sys_counter
[ 0.658529] VFS: Disk quotas dquot_6.6.0
[ 0.658654] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.659143] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.659581] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr , base=0x00000000d7000000, size=0x19000000
[ 0.659597] dma-vpr: heap size is not multiple of cma_chunk_size heap_info-> num_chunks (13) rem_chunk_size(0x1000000)
[ 0.659852] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.659859] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap =vpr create successful
[ 0.659874] tegra-carveouts tegra-carveouts: assigned reserved memory node vp r-carveout
[ 0.659921] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0 x0000000040001000,258048
[ 0.659928] tegra-carveouts tegra-carveouts: assigned reserved memory node ir am-carveout
[ 0.659952] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.659960] nvmap_page_pool_init: Total RAM pages: 1010866
[ 0.659965] nvmap_page_pool_init: nvmap page pool size: 126358 pages (493 MB)
[ 0.660045] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.660464] misc nvmap: created heap iram base 0x0000000040001000 size (252Ki B)
[ 0.661157] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600 KiB)
[ 0.670974] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.671426] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.671773] thermal thermal_zone2: Registering thermal zonport module.
[ 0.677438] RPC: Registered tcp transport module.
[ 0.677443] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.677458] PCI: CLS 0 bytes, default 64
[ 0.677720] Trying to unpack rootfs image as initramfs...
[ 0.972004] Freeing initrd memory: 6992K
[ 0.981938] host1x 50000000.host1x: initialized
[ 0.983760] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av ailable
[ 0.987065] audit: initializing netlink subsys (disabled)
[ 0.987135] audit: type=2000 audit(0.839:1): initialized
[ 0.987795] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.997563] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.999060] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.999842] 9p: Installing v9fs 9p2000 file system support
[ 1.003124] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 40)
[ 1.003284] io scheduler noop registered
[ 1.003568] io scheduler cfq registered (default)
[ 1.006345] gic 702f9000.agic: GIC IRQ controller registered
[ 1.009320] iommu: Adding device 702ef000.adsp to group 33
[ 1.018615] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.018787] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.019467] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8a29412
[ 1.019474] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_ 0 = 0x4
[ 1.021071] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.021172] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.021262] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.021453] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.021543] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.021632] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.021721] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.021811] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.021933] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.022022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.028215] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.029934] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.031841] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.033108] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.033463] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.034802] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:c amera_platform_driver probe
[ 1.035017] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1 500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.035238] Adding domain tsec-pd to PM domain host1x-pd
[ 1.037450] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.038345] tsec 54500000.tsec: initialized
[ 1.039983] tsec 54100000.tsecb: initialized
[ 1.040705] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.044166] nvdec 54480000.nvdec: initialized
[ 1.045231] Adding domain vic03-pd to PM domain host1x-pd
[ 1.045416] Adding domain msenc-pd to PM domain host1x-pd
[ 1.045585] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.049498] falcon 54340000.vic: initialized
[ 1.050816] falcon 544c0000.nvenc: initialized
[ 1.052187] falcon 54380000.nvjpg: initialized
[ 1.056619] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FF F irq=96
[ 1.056664] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.056701] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.056764] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.056854] display board info: id 0x0, fab 0x0
[ 1.056908] generic_infoframe_type: 0x87
[ 1.056980] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.056986] tegra_cec 70015000.tegra_cec: probed
[ 1.057063] tegradc tegradc.0: DT parsed successfully
[ 1.057116] tegradc tegradc.0: Display dc.ffffff800abc0000 registered with id =0
[ 1.064670] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 cha nnels
[ 1.069092] tegradc tegradc.0: probed
[ 1.069908] Console: switching to colour frame buffer device 80x30
[ 1.069942] tegradc tegradc.0: fb registered
[ 1.070254] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 chan nels
[ 1.071441] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check d isabled
[ 1.071450] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initi alized
[ 1.071626] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.071746] tegradc tegradc.1: No lt-data, using default setting
[ 1.071789] tegradc tegradc.1: No hpd-gpio in DT
[ 1.071841] tegradc tegradc.1: DT parsed successfully
[ 1.071894] tegradc tegradc.1: Display dc.ffffff800ad40000 registered with id =1
[ 1.072098] kfuse 7000fc00.kfuse: initialized
[ 1.073332] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-suppl y not available
[ 1.073482] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.074332] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.075372] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.075383] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.075787] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator regis tration passed
[ 1.579200] Host read timeout at address 545c00c4
[ 1.579611] vdd-gpu: applied init 1000000uV constraint
[ 1.579620] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.580028] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator regis tration passed
[ 1.580817] tegradc tegradc.1: probed
[ 1.581168] tegradc tegradc.1: fb registered
[ 1.584165] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.584261] No Device Node present for smmu client: serial8250 !!
[ 1.584271] platform serial8250: No iommus property found in DT node, got swg ids from fixup(101004000)
[ 1.584309] iommu: Adding device serial8250 to group 35
[ 1.584391] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.584398] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.584407] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.584423] tegradc tegradc.1: blank - powerdown
[ 1.584447] extcon-disp-state extcon:disp-state: cable 44 state 0 already set .
[ 1.584452] Extcon DP: HPD disabled
[ 1.584456] hpd: hpd_switch 0
[ 1.584460] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.584469] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.584476] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.586947] console [ttyS0] disabled
[ 1.587050] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.597351] console [ttyS0] enabled
[ 1.598423] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.598736] serial-tegra 70006200.serial: RX in PIO mode
[ 1.598827] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.599807] [drm] Initialized
[ 1.610362] brd: module loaded
[ 1.615519] loop: module loaded
[ 1.615599] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.615712] tegra_profiler: auth: init
[ 1.617104] THERMAL EST: found 2 subdevs
[ 1.617111] THERMAL EST num_resources: 0
[ 1.617117] [THERMAL EST subdev 0]
[ 1.617124] [THERMAL EST subdev 1]
[ 1.617589] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.617594] THERMAL EST: thz register success.
[ 1.617776] THERMAL EST: end of probe, return err: 0
[ 1.619035] sd: No Scsi addr parsed to reserve index
[ 1.619074] hisi_sas: driver version v1.6
[ 1.626241] tun: Universal TUN/TAP device driver, 1.6
[ 1.626252] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.627415] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.627420] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.627471] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.627474] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.627539] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.627544] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.627587] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4 .4.0-k
[ 1.627591] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 1.628800] PPP generic driver version 2.4.2
[ 1.629014] PPP BSD Compression module registered
[ 1.629020] PPP Deflate Compression module registered
[ 1.629059] PPP MPPE Compression module registered
[ 1.629068] NET: Registered protocol family 24
[ 1.629144] usbcore: registered new interface driver r8152
[ 1.629189] usbcore: registered new interface driver asix
[ 1.629238] usbcore: registered new interface driver ax88179_178a
[ 1.629275] usbcore: registered new interface driver cdc_ether
[ 1.629317] usbcore: registered new interface driver net1080
[ 1.629360] usbcore: registered new interface driver cdc_subset
[ 1.629396] usbcore: registered new interface driver zaurus
[ 1.629459] usbcore: registered new interface driver cdc_ncm
[ 1.629665] VFIO - User Level meta-driver version: 0.3
[ 1.631167] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.631194] ehci-pci: EHCI PCI platform driver
[ 1.631241] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.631252] ohci-pci: OHCI PCI platform driver
[ 1.631294] ohci-platform: OHCI generic platform driver
[ 1.634366] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.634982] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.636181] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f974e800 id
[ 1.638453] usbcore: registered new interface driver uas
[ 1.638534] usbcore: registered new interface driver usb-storage
[ 1.638644] usbcore: registered new interface driver usbserial
[ 1.641872] tegra-xusb 70090000.xusb: Firmware timestamp: 2020-07-31 09:33:12 UTC, Version: 50.26 release
[ 1.641958] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.641986] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus nu mber 1
[ 1.642337] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.642801] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.642863] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.643176] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.643187] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.643200] usb usb1: Product: xHCI Host Controller
[ 1.643214] usb usb1: Manufacturer: Linux 4.9.299-tegra xhci-hcd
[ 1.643219] usb usb1: SerialNumber: 70090000.xusb
[ 1.644070] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.644089] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.644106] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.644119] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.644138] hub 1-0:1.0: USB hub found
[ 1.644149] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.644182] hub 1-0:1.0: 5 ports detected
[ 1.644795] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.644811] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus nu mber 2
[ 1.644917] usb usb2: We don't know the algorithms for LPM for this host, dis abling LPM.
[ 1.644935] mousedev: PS/2 mouse device common for all mice
[ 1.645027] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.645033] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.645038] usb usb2: Product: xHCI Host Controller
[ 1.645042] usb usb2: Manufacturer: Linux 4.9.299-tegra xhci-hcd
[ 1.645047] usbcore: registered new interface driver xpad
[ 1.645051] usb usb2: SerialNumber: 70090000.xusb
[ 1.645592] hub 2-0:1.0: USB hub found
[ 1.645634] hub 2-0:1.0: 4 ports detected
[ 1.646504] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.646511] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.665916] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.746579] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as r tc0
[ 1.749086] rtc rtc1: alarm rtc device
[ 1.749106] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.749137] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.749869] i2c /dev entries driver
[ 1.750118] usb usb2: usb_suspend_both: status 0
[ 1.752205] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.752695] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.752701] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.753642] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.776994] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.777124] imx219 7-0010: imx219_board_setup: error during i2c read probe (- 121)
[ 1.784822] imx219 7-0010: board setup failed
[ 1.789263] imx219: probe of 7-0010 failed with error -121
[ 1.789923] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.813219] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.813319] imx219 8-0010: imx219_board_setup: error during i2c read probe (- 121)
[ 1.820875] imx219 8-0010: board setup failed
[ 1.825305] imx219: probe of 8-0010 failed with error -121
[ 1.827197] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.829907] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.829914] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.830370] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 1.830388] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.830399] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when c pu reaches 100500 mC
[ 1.830529] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 1.830540] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.830548] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when g pu reaches 101000 mC
[ 1.830692] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 1.830703] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.830709] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot tem perature
[ 1.830915] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.831758] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.831816] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.831842] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.831860] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.831903] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.832859] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 1.832881] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.833075] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.833110] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling devi ce' registered
[ 1.833534] parse_throttle_dt_data: Num cap clks = 6
[ 1.833542] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.833557] parse_throttle_dt_data: clk=gpu type=4
[ 1.833588] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.833611] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.833634] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.833638] parse_throttle_dt_data: clk=emc type=3
[ 1.834085] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 1.834209] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 1.834353] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.835197] FAN dev name: pwm-fan
[ 1.835282] FAN:gpio request success.
[ 1.835344] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.835664] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.835840] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.835852] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.835990] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, st ate:2
[ 1.835996] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.836001] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.836006] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.836011] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.836016] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.836021] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.836026] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.836031] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1 , state:4
[ 1.836036] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1 , state:4
[ 1.838980] device-mapper: uevent: version 1.0.3
[ 1.839451] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-d evel@redhat.com
[ 1.845174] tegra210-cpufreq cpufreq: probe()...completed
[ 1.845938] sdhci: Secure Digital Host Controller Interface driver
[ 1.845940] sdhci: Copyright(c) Pierre Ossman
[ 1.845942] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.846302] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.852629] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.853138] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.854247] usbcore: registered new interface driver usbhid
[ 1.854249] usbhid: USB HID core driver
[ 1.855638] ashmem: initialized
[ 1.856558] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.856724] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.858989] nvpmodel: initialized successfulplatform probe
[ 1.878889] OPE platform probe successful
[ 1.889905] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.893915] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADM A 64-bit with 64 bit addr
[ 1.905565] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.905697] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.905851] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.905987] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.906115] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.906243] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.906371] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.906497] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.906626] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.906756] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.912728] usb 1-2: New USB device found, idVendor=2109, idProduct=2817
[ 1.912733] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.912737] usb 1-2: Product: USB2.0 Hub
[ 1.912740] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 1.913736] hub 1-2:1.0: USB hub found
[ 1.914004] hub 1-2:1.0: 4 ports detected
[ 1.918457] u32 classifier
[ 1.918459] Actions configured
[ 1.918527] Initializing XFRM netlink socket
[ 1.919236] NET: Registered protocol family 10
[ 1.919882] NET: Registered protocol family 17
[ 1.919894] NET: Registered protocol family 15
[ 1.919970] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.920018] Bluetooth: RFCOMM socket layer initialized
[ 1.920029] Bluetooth: RFCOMM ver 1.11
[ 1.920034] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.920038] Bluetooth: HIDP socket layer initialized
[ 1.920056] 9pnet: Installing 9P2000 support
[ 1.920093] Key type dns_resolver registered
[ 1.920513] Registered cp15_barrier emulation handler
[ 1.920519] Registered setend emulation handler
[ 1.921568] registered taskstats version 1
[ 1.922104] Adding domain ve2-pd to PM domain host1x-pd
[ 1.922357] Adding domain ve-pd to PM domain host1x-pd
[ 1.924347] isp 54600000.isp: initialized
[ 1.925320] isp 54680000.isp: initialized
[ 1.935427] last reset is due to software reset
[ 1.935431] KERNEL: PMC reset status reg: 0x3
[ 1.935489] BL: PMC reset status reg: 0x3
[ 1.935491] BL: PMIC poweroff Event Recorder: 0x0
[ 1.936958] clk_cbus_recalc_rate: no gbus parent
[ 1.936964] clk_cbus_round_rate: no gbus parent
[ 1.936966] clk_cbus_round_rate: no gbus parent
[ 1.936971] clk_cbus_recalc_rate: no gbus parent
[ 1.937073] clk_cbus_recalc_rate: no gbus parent
[ 1.937077] clk_cbus_round_rate: no gbus parent
[ 1.937079] clk_cbus_round_rate: no gbus parent
[ 1.937083] clk_cbus_recalc_rate: no gbus parent
[ 1.937776] tegra_dvfs: GPU-cap: registered
[ 1.937867] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200u V, scaling enabled
[ 1.937870] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500 uV, scaling enabled
[ 1.937872] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000u V, scaling enabled
[ 1.940177] tegra_dvfs: vdd-gpu-vts: registered
[ 1.940896] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor co oling device' registered
[ 1.941544] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap coolin g device' registered
[ 1.942133] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.946044] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.950424] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 1.950526] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 1.954655] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 1.954758] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 1.957029] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 1.974635] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:05: 43 UTC (946688743)
[ 1.975652] vi 54080000.vi: vi_probe: ++
[ 1.975930] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.978689] vi 54080000.vi: initialized
[ 1.980722] vi 54080000.vi: subdev nvcsi--2 bound
[ 1.980831] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.981056] mmcblk mmc0:0001: Card claimed for testing.
[ 1.982290] Disable partitions left on by BL
[ 1.982294] disb
[ 1.982342] bwmgr: missing cdev-type property
[ 1.982432] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 1.982438] DRAM derating cdev registered.
[ 1.983311] ALSA device list:
[ 1.983315] #0: tegra-hda at 0x70038000 irq 82
[ 1.983317] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.986671] Freeing unused kernel memory: 8640K
[ 2.010120] Root device found: sda1
[ 2.036977] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 2.056128] usb 2-1: New USB device found, idVendor=2109, idProduct=0817
[ 2.056133] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.056136] usb 2-1: Product: USB3.0 Hub
[ 2.056140] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 2.057063] hub 2-1:1.0: USB hub found
[ 2.057229] hub 2-1:1.0: 4 ports detected
[ 2.069908] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 2.069911] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.383817] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.437910] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 2.457908] usb 1-2: usb_suspend_both: status 0
[ 2.457969] usb usb1: usb_suspend_both: status 0
[ 2.602477] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[ 2.625520] usb 2-1.1: New USB device found, idVendor=8564, idProduct=4000
[ 2.625526] usb 2-1.1: New USB device strings: Mfr=3, Product=4, SerialNumber =5
[ 2.625529] usb 2-1.1: Product: Transcend
[ 2.625533] usb 2-1.1: Manufacturer: TS-RDF5
[ 2.625536] usb 2-1.1: SerialNumber: 000000000039
[ 2.626553] usb-storage 2-1.1:1.0: USB Mass Storage device detected
[ 2.626841] scsi host0: usb-storage 2-1.1:1.0
[ 2.793695] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.795770] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.899210] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.899215] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.899218] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.899222] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pre f]
[ 2.899225] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.899246] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.899313] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.899430] iommu: Adding device 0000:00:02.0 to group 37
[ 2.899495] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), rec onfiguring
[ 2.899603] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.899629] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.899661] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref ]
[ 2.899684] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref ]
[ 2.899829] pci 0000:01:00.0: supports D1 D2
[ 2.899832] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.899970] iommu: Adding device 0000:01:00.0 to group 38
[ 2.909947] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.909973] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64b it pref]
[ 2.909977] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.909982] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bi t pref]
[ 2.910001] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bi t pref]
[ 2.910018] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.910026] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.910030] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.910036] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bi t pref]
[ 2.910221] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.910224] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.910228] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.910306] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.910467] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.910484] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.931624] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.931684] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found va lid ethernet address 48:b0:2d:5b:5b:1d from device tree
[ 2.932098] r8168: This product is covered by one or more of the following pa tents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.932112] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@real tek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, ple ase see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it un der certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.635605] scsi 0:0:0:0: Direct-Access TS-RDF5 SD Transcend TS37 PQ : 0 ANSI: 6
[ 3.897523] sd 0:0:0:0: [sda] 486637568 512-byte logical blocks: (249 GB/232 GiB)
[ 3.898451] sd 0:0:0:0: [sda] Write Protect is off
[ 3.898456] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 3.899259] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doe sn't support DPO or FUA
[ 3.912011] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10 sda11 sd a12 sda13 sda14
[ 3.915746] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.044174] Found dev node: /dev/sda1
[ 4.094402] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.096319] Rootfs mounted over sda1
[ 4.121110] Switching from initrd to actual rootfs
[ 4.349269] systemd[1]: System time before build time, advancing clock.
[ 4.377100] cgroup: cgroup2: unknown option "nsdelegate"
[ 4.399061] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL + XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr id)
[ 4.399851] systemd[1]: Detected architecture arm64.
[ 4.422317] systemd[1]: Set hostname to <nano>.
[ 4.636126] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not sup port BPF/cgroup based firewalling.
[ 4.636135] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warni ng is only shown for the first loaded unit using IP firewalling.)
[ 4.810980] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.812601] systemd[1]: Created slice User and Session Slice.
[ 4.812756] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.812778] systemd[1]: Reached target User and Group Name Lookups.
[ 4.812839] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.813604] systemd[1]: Created slice System Slice.
[ 4.814500] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.814675] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.053047] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 5.125410] systemd-journald[2043]: Received request to flush runtime journal from PID 1
[ 6.412324] random: crng init done
[ 6.415729] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.551524] using random self ethernet address
[ 6.556017] using random host ethernet address
[ 7.520814] Mass Storage Function, version: 2009/09/11
[ 7.520820] LUN: removable file: (no medium)
[ 7.525475] using random self ethernet address
[ 7.529972] using random host ethernet address
[ 7.560673] rndis0: HOST MAC 02:9f:9a:bd:72:00
[ 7.560744] rndis0: MAC 02:9f:9a:bd:72:01
[ 7.561597] usb0: HOST MAC 02:9f:9a:bd:72:02
[ 7.561729] usb0: MAC 02:9f:9a:bd:72:03
[ 7.561758] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 7.570941] l4tbr0: port 1(rndis0) entered blocking state
[ 7.570946] l4tbr0: port 1(rndis0) entered disabled state
[ 7.571519] device rndis0 entered promiscuous mode
[ 7.580388] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 7.586374] l4tbr0: port 2(usb0) entered blocking state
[ 7.586379] l4tbr0: port 2(usb0) entered disabled state
[ 7.586568] device usb0 entered promiscuous mode
[ 7.595922] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.814651] android_work: did not send uevent (0 0 (null))
[ 7.847387] android_work: sent uevent USB_STATE=CONNECTED
[ 7.873009] configfs-gadget gadget: high-speed config #1: c
[ 7.873040] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 7.873056] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 7.873072] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 7.873177] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 7.873193] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 7.873208] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 7.873242] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 7.873261] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 7.873282] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 7.873981] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 7.874115] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.928244] l4tbr0: port 1(rndis0) entered blocking state
[ 11.928249] l4tbr0: port 1(rndis0) entered forwarding state
[ 11.928360] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 11.928375] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 11.965782] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.971461] eth0: 0xffffff800ab03000, 48:b0:2d:5b:5b:1d, IRQ 406
[ 12.039020] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.413407] tegradc tegradc.0: blank - powerdown
[ 16.835785] tegradc tegradc.0: blank - powerdown
[ 16.979700] device-mapper: table: 253:0: thin-pool: unknown target type
[ 16.987207] device-mapper: ioctl: error adding target to table
[ 17.197054] tegradc tegradc.0: blank - powerdown
[ 17.489099] tegradc tegradc.0: blank - powerdown
[ 17.777029] tegradc tegradc.0: blank - powerdown
[ 18.061729] tegradc tegradc.0: blank - powerdown
[ 18.345799] tegradc tegradc.0: blank - powerdown
[ 18.628222] tegradc tegradc.0: blank - powerdown
[ 18.913625] tegradc tegradc.0: blank - powerdown
[ 19.217702] tegradc tegradc.0: blank - powerdown
[ 19.355016] device-mapper: table: 253:0: thin-pool: unknown target type
[ 19.365200] device-mapper: ioctl: error adding target to table
[ 19.549060] tegradc tegradc.0: blank - powerdown
[ 19.833762] tegradc tegradc.0: blank - powerdown
[ 20.120716] tegradc tegradc.0: blank - powerdown
[ 20.401120] tegradc tegradc.0: blank - powerdown
[ 20.684054] tegradc tegradc.0: blank - powerdown
[ 20.973481] tegradc tegradc.0: blank - powerdown
[ 21.260849] tegradc tegradc.0: blank - powerdown
[ 21.571555] tegradc tegradc.0: blank - powerdown
[ 21.716015] device-mapper: table: 253:0: thin-pool: unknown target type
[ 21.722755] device-mapper: ioctl: error adding target to table
[ 21.906434] tegradc tegradc.0: blank - powerdown
[ 22.197143] tegradc tegradc.0: blank - powerdown
[ 22.482755] tegradc tegradc.0: blank - powerdown
[ 22.763894] tegradc tegradc.0: blank - powerdown
[ 23.054270] tegradc tegradc.0: blank - powerdown
[ 23.361477] tegradc tegradc.0: blank - powerdown
[ 23.642936] tegradc tegradc.0: blank - powerdown
[ 23.926520] tegradc tegradc.0: bl[ 29.634982] tegradc tegradc.0: blank - po werdown
[ 29.922539] tegradc tegradc.0: blank - powerdown
[ 30.208929] tegradc tegradc.0: blank - powerdown
[ 30.498183] tegradc tegradc.0: blank - powerdown
[ 30.791711] tegradc tegradc.0: blank - powerdown
[ 31.077821] tegradc tegradc.0: blank - powerdown
[ 31.363528] tegradc tegradc.0: blank - powerdown
[ 31.652269] tegradc tegradc.0: blank - powerdown
[ 31.939776] tegradc tegradc.0: blank - powerdown
[ 32.229034] tegradc tegradc.0: blank - powerdown
[ 32.518141] tegradc tegradc.0: blank - powerdown
[ 32.807500] tegradc tegradc.0: blank - powerdown
[ 33.100919] tegradc tegradc.0: blank - powerdown
[ 33.390052] tegradc tegradc.0: blank - powerdown
[ 33.676485] tegradc tegradc.0: blank - powerdown
[ 33.906026] vdd-fan: disabling
[ 33.906031] vdd-usb-vbus: disabling
[ 33.906033] vdd-usb-vbus2: disabling
[ 33.906042] vddio-sdmmc-ap: disabling
[ 33.906162] vddio-sdmmc3-ap: disabling
[ 33.906264] vdd-3v3-sd: disabling
[ 33.906269] avdd-io-edp-1v05: disabling
[ 33.906272] vdd-usb-hub-en: disabling
[ 33.964672] tegradc tegradc.0: blank - powerdown
[ 34.252521] tegradc tegradc.0: blank - powerdown
[ 34.543331] tegradc tegradc.0: blank - powerdown
[ 34.829491] tegradc tegradc.0: blank - powerdown
[ 35.121378] tegradc tegradc.0: blank - powerdown
[ 35.444225] tegradc tegradc.0: blank - powerdown
[ 35.729424] tegradc tegradc.0: blank - powerdown
[ 36.013490] tegradc tegradc.0: blank - powerdown
[ 36.298520] tegradc tegradc.0: blank - powerdown
[ 36.583526] tegradc tegradc.0: blank - powerdown
[ 36.868410] tegradc tegradc.0: blank - powerdown
[ 37.159111] tegradc tegradc.0: blank - powerdown
[ 37.448634] tegradc tegradc.0: blank - powerdown
[ 37.734989] tegradc tegradc.0: blank - powerdown
[ 38.024541] tegradc tegradc.0: blank - powerdown
[ 38.314532] tegradc tegradc.0: blank - powerdown
[ 38.602523] tegradc tegradc.0: blank - powerdown
[ 38.886339] tegradc tegradc.0: blank - powerdown
[ 39.174815] tegradc tegradc.0: blank - powerdown
[ 39.469632] tegradc tegradc.0: blank - powerdown
[ 39.759478] tegradc tegradc.0: blank - powerdown
[ 40.044761] tegradc tegradc.0: blank - powerdown
[ 40.333079] tegradc tegradc.0: blank - powerdown
[ 40.617675] tegradc tegradc.0: blank - powerdown
[ 40.909654] tegradc tegradc.0: blank - powerdown
[ 41.202493] tegradc tegradc.0: blank - powerdown
[ 41.488129] tegradc tegradc.0: blank - powerdown
[ 41.791465] tegradc tegradc.0: blank - powerdown
[ 42.079802] tegradc tegradc.0: blank - powerdown
[ 42.370294] tegradc tegradc.0: blank - powerdown
[ 42.659885] tegradc tegradc.0: blank - powerdown
[ 42.944011] tegradc tegradc.0: blank - powerdown
[ 43.232043] tegradc tegradc.0: blank - powerdown
[ 43.534421] tegradc tegradc.0: blank - powerdown
[ 43.828308] tegradc tegradc.0: blank - powerdown
[ 44.111016] tegradc tegradc.0: blank - powerdown
[ 44.411661] tegradc tegradc.0: blank - powerdown
[ 44.700355] tegradc tegradc.0: blank - powerdown
[ 44.984773] tegradc tegradc.0: blank - powerdown
[ 45.279043] tegradc tegradc.0: blank - powerdown
[ 45.568957] tegradc tegradc.0: blank - powerdown
[ 45.862715] tegradc tegradc.0: blank - powerdown
[ 46.150728] tegradc tegradc.0: blank - powerdown
[ 46.450955] tegradc tegradc.0: blank - powerdown
[ 46.741974] tegradc tegradc.0: blank - powerdown
[ 47.042891] tegradc tegradc.0: blank - powerdown
[ 47.328348] tegradc tegradc.0: blank - powerdown
[ 47.630065] tegradc tegradc.0: blank - powerdown
[ 47.926850] tegradc tegradc.0: blank - powerdown
[ 48.228734] tegradc tegradc.0: blank - powerdown
[ 48.523880] tegradc tegradc.0: blank - powerdown
[ 48.819969] tegradc tegradc.0: blank - powerdown
[ 49.108735] tegradc tegradc.0: blank - powerdown
[ 49.398396] tegradc tegradc.0: blank - powerdown
[ 49.698891] tegradc tegradc.0: blank - powerdown
[ 50.008886] tegradc tegradc.0: blank - powerdown
[ 50.297366] tegradc tegradc.0: blank - powerdown
[ 50.598552] tegradc tegradc.0: blank - powerdown
[ 50.896695] tegradc tegradc.0: blank - powerdown
[ 51.190885] tegradc tegradc.0: blank - powerdown
[ 51.482864] tegradc tegradc.0: blank - powerdown
[ 51.822966] tegradc tegradc.0: blank - powerdown
[ 52.115155] tegradc tegradc.0: blank - powerdown
[ 52.408908] tegradc tegradc.0: blank - powerdown
[ 52.700034] tegradc tegradc.0: blank - powerdown
[ 52.999383] tegradc tegradc.0: blank - powerdown
[ 53.305436] tegradc tegradc.0: blank - powerdown
[ 53.597267] tegradc tegradc.0: blank - powerdown
[ 53.891149] tegradc tegradc.0: blank - powerdown
[ 54.195330] tegradc tegradc.0: blank - powerdown
[ 54.492864] tegradc tegradc.0: blank - powerdown
[ 54.800814] tegradc tegradc.0: blank - powerdown
[ 55.152398] tegradc tegradc.0: blank - powerdown
[ 55.461676] tegradc tegradc.0: blank - powerdown
[ 55.756212] tegradc tegradc.0: blank - powerdown
[ 56.060462] tegradc tegradc.0: blank - powerdown
[ 56.353994] tegradc tegradc.0: blank - powerdown
[ 56.650855] tegradc tegradc.0: blank - powerdown
[ 56.943127] tegradc tegradc.0: blank - powerdown
[ 57.249510] tegradc tegradc.0: blank - powerdown
[ 57.541323] tegradc tegradc.0: blank - powerdown
[ 57.834614] tegradc tegradc.0: blank - powerdown
[ 58.125597] tegradc tegradc.0: blank - powerdown
[ 58.430463] tegradc tegradc.0: blank - powerdown
[ 58.740981] tegradc tegradc.0: blank - powerdown
[ 59.044517] tegradc tegradc.0: blank - powerdown
[ 59.346908] tegradc tegradc.0: blank - powerdown
[ 59.654552] tegradc tegradc.0: blank - powerdown
[ 59.954454] tegradc tegradc.0: blank - powerdown
[ 60.249041] tegradc tegradc.0: blank - powerdown
[ 60.542148] tegradc tegradc.0: blank - powerdown
[ 60.848829] tegradc tegradc.0: blank - powerdown
[ 61.140236] tegradc tegradc.0: blank - powerdown
[ 61.445297] tegradc tegradc.0: blank - powerdown
[ 61.743972] tegradc tegradc.0: blank - powerdown
[ 62.044658] tegradc tegradc.0: blank - powerdown
[ 62.347015] tegradc tegradc.0: blank - powerdown
[ 62.645910] tegradc tegradc.0: blank - powerdown
[ 62.941297] tegradc tegradc.0: blank - powerdown
[ 63.253724] tegradc tegradc.0: blank - powerdown
[ 63.551869] tegradc tegradc.0: blank - powerdown
[ 63.860400] tegradc tegradc.0: blank - powerdown
[ 64.155784] tegradc tegradc.0: blank - powerdown
[ 64.454663] tegradc tegradc.0: blank - powerdown
[ 64.751807] tegradc tegradc.0: blank - powerdown
[ 65.050616] tegradc tegradc.0: blank - powerdown
[ 65.358106] tegradc tegradc.0: blank - powerdown
[ 65.651514] tegradc tegradc.0: blank - powerdown
[ 65.956562] tegradc tegradc.0: blank - powerdown
[ 66.253238] tegradc tegradc.0: blank - powerdown
[ 66.548560] tegradc tegradc.0: blank - powerdown
[ 66.842563] tegradc tegradc.0: blank - powerdown
[ 67.146104] tegradc tegradc.0: blank - powerdown
[ 67.443936] tegradc tegradc.0: blank - powerdown
[ 67.744021] tegradc tegradc.0: blank - powerdown
[ 68.047752] tegradc tegradc.0: blank - powerdown
[ 68.363114] tegradc tegradc.0: blank - powerdown
[ 68.660077] tegradc tegradc.0: blank - powerdown
for /var/log/Xorg.0.log
robotika@nano:~$ cat /var/log/Xorg.0.log
[ 129.994] (--) Log file renamed from "/var/log/Xorg.pid-14300.log" to "/var/log/Xorg.0.log"
[ 129.995]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 129.995] X Protocol Version 11, Revision 0
[ 129.995] Build Operating System: Linux 4.15.0-163-generic aarch64 Ubuntu
[ 129.995] Current Operating System: Linux nano 4.9.299-tegra #1 SMP PREEMPT Tue Nov 22 09:24:39 PST 2022 aarch64
[ 129.995] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/sda1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[ 129.995] Build Date: 14 December 2021 04:14:51PM
[ 129.995] xorg-server 2:1.19.6-1ubuntu4.10 (For technical support please see http://www.ubuntu.com/support)
[ 129.995] Current version of pixman: 0.34.0
[ 129.995] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 129.995] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 129.995] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Aug 3 04:16:43 2023
[ 129.995] (==) Using config file: "/etc/X11/xorg.conf"
[ 129.995] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 129.996] (==) No Layout section. Using the first Screen section.
[ 129.996] (==) No screen section available. Using defaults.
[ 129.996] (**) |-->Screen "Default Screen Section" (0)
[ 129.996] (**) | |-->Monitor "<default monitor>"
[ 129.997] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 129.997] (**) | |-->Device "Tegra0"
[ 129.997] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 129.997] (==) Automatically adding devices
[ 129.997] (==) Automatically enabling devices
[ 129.997] (==) Automatically adding GPU devices
[ 129.997] (==) Automatically binding GPU devices
[ 129.997] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 129.997] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 129.997] Entry deleted from font path.
[ 129.997] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 129.997] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 129.997] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 129.997] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 129.997] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 129.997] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 129.997] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 129.997] (II) Loader magic: 0x556e947010
[ 129.997] (II) Module ABI versions:
[ 129.997] X.Org ANSI C Emulation: 0.4
[ 129.997] X.Org Video Driver: 23.0
[ 129.997] X.Org XInput driver : 24.1
[ 129.997] X.Org Server Extension : 10.0
[ 129.999] (++) using VT number 1
[ 130.004] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c372
[ 130.005] (II) no primary bus or device found
[ 130.005] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 130.005] (II) "glx" will be loaded by default.
[ 130.005] (II) LoadModule: "extmod"
[ 130.005] (II) Module "extmod" already built-in
[ 130.005] (II) LoadModule: "glx"
[ 130.006] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 130.008] (II) Module glx: vendor="X.Org Foundation"
[ 130.008] compiled for 1.19.6, module version = 1.0.0
[ 130.008] ABI class: X.Org Server Extension, version 10.0
[ 130.008] (II) LoadModule: "nvidia"
[ 130.008] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 130.009] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 130.009] compiled for 4.0.2, module version = 1.0.0
[ 130.009] Module class: X.Org Video Driver
[ 130.009] (II) NVIDIA dlloader X Driver 32.7.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-5434-d8000) Sat Feb 19 08:59:21 PST 2022
[ 130.009] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 130.009] (WW) Falling back to old probe method for NVIDIA
[ 130.009] (II) Loading sub module "fb"
[ 130.010] (II) LoadModule: "fb"
[ 130.010] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 130.010] (II) Module fb: vendor="X.Org Foundation"
[ 130.010] compiled for 1.19.6, module version = 1.0.0
[ 130.010] ABI class: X.Org ANSI C Emulation, version 0.4
[ 130.010] (II) Loading sub module "wfb"
[ 130.010] (II) LoadModule: "wfb"
[ 130.011] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 130.011] (II) Module wfb: vendor="X.Org Foundation"
[ 130.011] compiled for 1.19.6, module version = 1.0.0
[ 130.011] ABI class: X.Org ANSI C Emulation, version 0.4
[ 130.011] (II) Loading sub module "ramdac"
[ 130.011] (II) LoadModule: "ramdac"
[ 130.011] (II) Module "ramdac" already built-in
[ 130.012] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 130.012] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 130.012] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 130.012] (==) NVIDIA(0): RGB weight 888
[ 130.012] (==) NVIDIA(0): Default visual is TrueColor
[ 130.012] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 130.012] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 130.012] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[ 130.012] (**) NVIDIA(0): Enabling 2D acceleration
[ 130.013] (II) Loading sub module "glxserver_nvidia"
[ 130.013] (II) LoadModule: "glxserver_nvidia"
[ 130.013] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 130.019] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 130.019] compiled for 4.0.2, module version = 1.0.0
[ 130.019] Module class: X.Org Server Extension
[ 130.019] (II) NVIDIA GLX Module 32.7.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-5434-d8000) Sat Feb 19 08:58:33 PST 2022
[ 130.020] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 130.020] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 130.020] (II) UnloadModule: "nvidia"
[ 130.020] (II) UnloadSubModule: "glxserver_nvidia"
[ 130.020] (II) Unloading glxserver_nvidia
[ 130.020] (II) UnloadSubModule: "wfb"
[ 130.020] (II) UnloadSubModule: "fb"
[ 130.020] (EE) Screen(s) found, but none have a usable configuration.
[ 130.020] (EE)
Fatal server error:
[ 130.020] (EE) no screens found(EE)
[ 130.020] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 130.020] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 130.020] (EE)
[ 130.022] (EE) Server terminated with error (1). Closing log file.
