I’ve tried to run a program on a jetson nano that will display 4 UDP video streams on a monitor connected to the jetson nano via HDMI. From what I’ve read, it is possible to only display 2 video streams (as the jetson has only 2 overlays). Has anyone displayed more than 2 video streams via something like Qt multimedia successfully?
For this use-case we would suggest composite multiple video plane into single plane. You can use nvcompositor plugin in gstreamer. Or call NvBufferComposite() in jetson_multimedia_api.
So you are confirming that this is indeed the case… that you can only show two separate video windows on the a jetson nano display?
R,
Charles Bryant
chas.bryant@gmail.com
Not sure about using QT. This would need other users to share experience.
If you use gstreamer and use window-based nv3dsink or nveglglessink, you can create more-than-two windows. The constraint you mentioned is specific to using nvoverlaysink
