Hello there,
A beginner here struggling to run his (Jetson Nano P3450) board for the first time!
for some reason it’s not booting and I have been told that I have to re-flash it using the SDK manager in a previous post.
SDK Manager Setup:
- The module suggested by the SDK manager contains the version P3449 and not P3450 (in case it makes any difference.
- I have selected JETPACK 4.6 (REV.3)
- Target Components : Jetson OS , and Jetson SDK Components
I am getting dependency errors and I couldn’t install anything on the Target. The terminal output is provided below.
Thanks in advance.
21:01:27 INFO: File System and OS - target_image: #!/bin/bash
21:01:27 INFO: File System and OS - target_image: set -e
21:01:27 INFO: File System and OS - target_image: sudo tar xpf /media/ubayda/125ABEC35ABEA2C1/Jetson/Host/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2
21:01:27 INFO: File System and OS - target_image: cd …
21:01:27 INFO: File System and OS - target_image: sudo ./apply_binaries.sh
21:01:27 INFO: File System and OS - target_image: sudo mkdir -p rootfs/opt/nvidia/deb_repos
21:01:27 INFO: File System and OS - target_image: **********************
21:01:27 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP.sh
21:12:30 INFO: File System and OS - target_image: Usig rootfs directory of: /media/ubayda/125ABEC35ABEA2C1/Jetson/Target/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs
21:12:30 INFO: File System and OS - target_image: ||||||||||||||||||||||| ERROR |||||||||||||||||||||||
21:12:30 INFO: File System and OS - target_image: -----------------------------------------------------
21:12:30 INFO: File System and OS - target_image: 1. The root filesystem, provided with this package,
21:12:30 INFO: File System and OS - target_image: has to be extracted to this directory:
21:12:30 INFO: File System and OS - target_image: /media/ubayda/125ABEC35ABEA2C1/Jetson/Target/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs
21:12:30 INFO: File System and OS - target_image: 2. The root filesystem, provided with this package,
21:12:30 INFO: File System and OS - target_image: has to be extracted with ‘sudo’ to this directory:
21:12:30 INFO: File System and OS - target_image: Consult the Development Guide for instructions on
21:12:30 INFO: File System and OS - target_image: extracting and flashing your device.
21:12:30 INFO: File System and OS - target_image: |||||||||||||||||||||||||||||||||||||||||||||||||||||
21:12:30 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
21:12:30 INFO: File System and OS - target_image: [host] [ 197.43 MB used. Disk Avail: 34.48 GB ]
21:12:30 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP Install took 12m14s ]
21:12:30 ERROR: File System and OS - target_image: command terminated with error
21:12:30 SUMMARY: File System and OS - target_image: First Error: Installation failed.
22:05:00 INFO: File System and OS - target_image: verifying checksum of /media/ubayda/125ABEC35ABEA2C1/Jetson/Host/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2
22:06:38 INFO: File System and OS - target_image: Found file /media/ubayda/125ABEC35ABEA2C1/Jetson/Host/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2 with correct checksum, skip downloading.
22:08:48 INFO: File System and OS - target_image: verifying checksum of /media/ubayda/125ABEC35ABEA2C1/Jetson/Host/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2
22:10:33 INFO: File System and OS - target_image: Found file /media/ubayda/125ABEC35ABEA2C1/Jetson/Host/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2 with correct checksum, skip downloading.tson Nano [developer kit version]
P3
22:11:10 DEBUG: File System and OS - target_image: using adapter to install NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP@JETSON_NANO_TARGETS to /media/ubayda/125ABEC35ABEA2C1/Jetson/Target/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs/
22:11:10 INFO: File System and OS - target_image: NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP include 1 package
22:11:10 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP.sh
22:11:10 INFO: File System and OS - target_image: *begin sudo apt-get install -y qemu-user-static , 5
22:11:12 INFO: File System and OS - target_image: Reading package lists…
22:11:12 INFO: File System and OS - target_image: Building dependency tree…
22:11:12 INFO: File System and OS - target_image: Reading state information…
22:11:13 INFO: File System and OS - target_image: qemu-user-static is already the newest version (1:2.11+dfsg-1ubuntu7.38).
22:11:13 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
22:11:14 INFO: File System and OS - target_image: *begin sudo apt-get install -y python , 5
22:11:14 INFO: File System and OS - target_image: Reading package lists…ubayda
22:11:14 INFO: File System and OS - target_image: Building dependency tree…
22:11:14 INFO: File System and OS - target_image: Reading state information…
22:11:15 INFO: File System and OS - target_image: python is already the newest version (2.7.15~rc1-1).
22:11:15 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
22:11:15 INFO: File System and OS - target_image: [ Package Install Started ]
22:11:15 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP.sh
22:18:58 INFO: File System and OS - target_image: Using rootfs directory of: /media/ubayda/125ABEC35ABEA2C1/Jetson/Target/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/rootfs
22:18:58 ERROR: File System and OS - target_image: command terminated with error
