I have recently started using Jetson nano, 4gb with jetpack 4.5 version and I updated and upgraded it, the rebooted it. Everything was going fine and it was taking a long time, but it lost power in between that process, I re powered it, but now it’s stuck in the reboot process only, last thing that comes is “[ 7.184484 Bridge fireballing registered” and a cursor is blinking, what should I do to reboot it properly.
Hi prashant.kumar.ug21,
Are you using the devkit or custom board for Jetson Nano?
Could you help to share the full serial console log for further check?
I refreshed the sd card
We would like to check the FULL serial console log as file here for further check.
From you current screenshot, do you connect any wireless module on your board?
Yes I had a wireless module connected at the time, I don’t have those logs, and I wasn’t able to all of them.
Please remove the wireless module and power up again to check if the issue still exists.
If so, please capture the serial console log for further check.
You could refer to the following instruction to capture logs.
Jetson Nano & NX Style - Serial Debug Console - JetsonHacks
