Jetson Nano reboots on high GPU load
I have a Jetson Nano (production module) mounted on a Seed Studio carrier board J101.
Sometimes when I’m using the GPU on high load, it restarts.
I have found this by storing tegrastats and observing last thing it writes is a 99% frequency on GPU
RAM 3245/3964MB (lfb 107x4MB) SWAP 698/1982MB (cached 38MB) IRAM 0/252kB(lfb 252kB) CPU [11%@1326,35%@1326,13%@1326,11%@1326] EMC_FREQ 18%@1600 GR3D_FREQ 99%@921 VIC_FREQ 9%@192 APE 25 PLL@49C CPU@54.5C PMIC@50C GPU@51.5C AO@64C thermal@52.5C POM_5V_IN 7274/3121 POM_5V_GPU 3570/557 POM_5V_CPU 894/463
I’m using the MAXN mode
sudo jetson_clocks --show
SOC family:tegra210 Machine:NVIDIA Jetson Nano Developer Kit
Online CPUs: 0-3
cpu0: Online=1 Governor=schedutil MinFreq=1200000 MaxFreq=1479000 CurrentFreq=1479000 IdleStates: WFI=1 c7=1
cpu1: Online=1 Governor=schedutil MinFreq=1200000 MaxFreq=1479000 CurrentFreq=1224000 IdleStates: WFI=1 c7=1
cpu2: Online=1 Governor=schedutil MinFreq=1200000 MaxFreq=1479000 CurrentFreq=1479000 IdleStates: WFI=1 c7=1
cpu3: Online=1 Governor=schedutil MinFreq=1200000 MaxFreq=1479000 CurrentFreq=1224000 IdleStates: WFI=1 c7=1
GPU MinFreq=76800000 MaxFreq=921600000 CurrentFreq=76800000
EMC MinFreq=204000000 MaxFreq=1600000000 CurrentFreq=1600000000 FreqOverride=0
Fan: PWM=80
NV Power Mode: MAXN
The power supply is the Raspberry 5 one (up to 27W) so power should not be a problem.
How can I find what is exactly happening? How can I prevent the machine to reboot on high loads?
Hi diego45,
Could you share the full serial console log when it restarts?
It seems you are running something in high loading.
Have you tried to configure a custom power mode configuration for your use case?
Hi Kevin,
Jetpack 4.6.4 (L4T 32.7.4)
I don’t see console logs at the time of restart, it just freezes and restarts, when I check the system logs I only see the startup log with no interesting info on it. Any suggestion where can I see some logs?
I didn’t try a custom power configuration. I assume your suggestion is to put a lower max frequency for the GPU, is that right?
How about /var/log/syslog on your board?
Yes, something like that to constraint the CPU/GPU frequency to optimize the performance instead of using unconstraint MAX-N mode.
Changing GPU max frequency to a lower value made it. It is now 80% of the GPU real max capacity but it is ok for the project.
