Jetson nano reboots with VFS error
I am trying flutter app build on my Jetson naono, however it causes reboot of the board even if I just build an app using “flutter build” command.
  • Jetson nano 4G version (2G version as well)
  • JetPack4.6.1
  • swap-file size 16GB
  • boot from SSD drive (/dev/sda1 500G)
Not sure if it is related to flutter app build.
I see “VFS: brelse: Trying to free free buffer” in dmesg log (below) and this is causing the reboot?
[   31.862118] vdd-usb-vbus: disabling
[   31.862120] vdd-usb-vbus2: disabling
[   31.862128] vdd-3v3-sd: disabling
[   31.862131] avdd-io-edp-1v05: disabling
[  166.952525] VFS: brelse: Trying to free free buffer
[  166.957507] ------------[ cut here ]------------
[  166.962126] WARNING: CPU: 2 PID: 7557 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/fs/buffer.c:1197 __brelse+0x4c/0x58
[  166.973491] Modules linked in: bnep xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype fuse iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack br_netfilter zram overlay r8188eu(C) cfg80211 userspace_alert uvcvideo nvgpu ip_tables x_tables
[  166.973545] CPU: 2 PID: 7557 Comm: clang Tainted: G         C      4.9.253-tegra #1
[  166.973547] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[  166.973550] task: ffffffc0db7a8e00 task.stack: ffffffc0b9c50000
[  166.973553] PC is at __brelse+0x4c/0x58
[  166.973556] LR is at __brelse+0x4c/0x58
[  166.973560] pc : [<ffffff800829bee4>] lr : [<ffffff800829bee4>] pstate: 40400005
[  166.973562] sp : ffffffc0b9c53650
[  166.973564] x29: ffffffc0b9c53650 x28: ffffffc0f27eb400
[  166.973570] x27: 0000000000000005 x26: ffffffc0c320ac80
[  166.973576] x25: ffffffc0b9c536c0 x24: ffffffc09a3b1138
[  166.973581] x23: ffffff8009841488 x22: ffffff8009841408
[  166.973586] x21: ffffffc09a3cd680 x20: 0000000000000010
[  166.973591] x19: ffffffc09a3b1138 x18: 0000000000000010
[  166.973595] x17: 0000000000000000 x16: 0000000000000000
[  166.973600] x15: ffffffffffffffff x14: ffffff808a16e5b7
[  166.973605] x13: ffffff800a16e5c5 x12: 0000000000000000
[  166.973609] x11: 0000000005f5e0ff x10: 0000000000000361
[  166.973614] x9 : 00000000ffffffd0 x8 : ffffff80083d7080
[  166.973619] x7 : ffffff8009ed44a8 x6 : ffffffc0feff3bf0
[  166.973624] x5 : ffffffc0feff3bf0 x4 : 0000000000000000
[  166.973628] x3 : ffffffc0feff97f8 x2 : ffffffc0feff3bf0
[  166.973633] x1 : ffffffc0db7a8e00 x0 : 0000000000000027
[  166.973639] ---[ end trace e3420ef78cf6360a ]---
[  166.978244] Call trace:
[  166.978248] [<ffffff800829bee4>] __brelse+0x4c/0x58
[  166.978252] [<ffffff800829c2a0>] bh_lru_install+0x120/0x1a0
[  166.978256] [<ffffff800829c4ec>] __find_get_block+0x1cc/0x1d8
[  166.978260] [<ffffff800829cffc>] __getblk_gfp+0x3c/0x348
[  166.978265] [<ffffff8008362390>] squashfs_bio_submit+0xe8/0x4f0
[  166.978269] [<ffffff8008362cb0>] __squashfs_read_data+0x160/0x268
[  166.978272] [<ffffff8008362ef4>] squashfs_read_data_async+0x4c/0x60
[  166.978276] [<ffffff80083673fc>] squashfs_readpages_block+0x1e4/0x3d8
[  166.978280] [<ffffff8008364c70>] __squashfs_readpages.isra.5+0x668/0x980
[  166.978283] [<ffffff8008364fc4>] squashfs_readpages+0x3c/0x78
[  166.978288] [<ffffff80081d47ec>] __do_page_cache_readahead+0x1ac/0x2a8
[  166.978293] [<ffffff80081c5bdc>] filemap_fault+0x2a4/0x6f0
[  166.978298] [<ffffff80081fcc78>] __do_fault+0x90/0x1d0
[  166.978302] [<ffffff80082017bc>] do_fault+0x25c/0x838
[  166.978306] [<ffffff8008203254>] handle_mm_fault+0x3f4/0x5f0
[  166.978312] [<ffffff80080a246c>] do_page_fault+0x254/0x480
[  166.978315] [<ffffff80080a2704>] do_translation_fault+0x6c/0x80
[  166.978319] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[  166.978322] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[  166.978325] [<ffffff8008083424>] el0_ia+0x18/0x1c
[  166.982963] VFS: brelse: Trying to free free buffer
[  166.987868] ------------[ cut here ]------------
[  166.992482] WARNING: CPU: 2 PID: 7557 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/fs/buffer.c:1197 __brelse+0x4c/0x58
[  167.003847] Modules linked in: bnep xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype fuse iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack br_netfilter zram overlay r8188eu(C) cfg80211 userspace_alert uvcvideo nvgpu ip_tables x_tables
[  167.003899] CPU: 2 PID: 7557 Comm: clang Tainted: G        WC      4.9.253-tegra #1
[  167.003901] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[  167.003904] task: ffffffc0db7a8e00 task.stack: ffffffc0b9c50000
[  167.003907] PC is at __brelse+0x4c/0x58
[  167.003910] LR is at __brelse+0x4c/0x58
[  167.003913] pc : [<ffffff800829bee4>] lr : [<ffffff800829bee4>] pstate: 40400005
[  167.003915] sp : ffffffc0b9c53650
[  167.003918] x29: ffffffc0b9c53650 x28: ffffffc0f27eb400
[  167.003923] x27: 0000000000000006 x26: ffffffc0c320ac80
[  167.003929] x25: ffffffc0b9c536c0 x24: ffffffc09a3b10d0
[  167.003933] x23: ffffff8009841488 x22: ffffff8009841408
[  167.003938] x21: ffffffc09a3cd618 x20: 0000000000000010
[  167.003943] x19: ffffffc09a3b10d0 x18: 0000000000000010
[  167.003948] x17: 0000000000000000 x16: 0000000000000000
[  167.003952] x15: ffffffffffffffff x14: ffffff808a16e5b7
[  167.003957] x13: ffffff800a16e5c5 x12: 0000000000000000
[  167.003962] x11: 0000000005f5e0ff x10: 0000000000000393
[  167.003966] x9 : 00000000ffffffd0 x8 : ffffff80083d7080
[  167.003971] x7 : ffffff8009ed44a8 x6 : ffffffc0feff3bf0
[  167.003976] x5 : ffffffc0feff3bf0 x4 : 0000000000000000
[  167.003980] x3 : ffffffc0feff97f8 x2 : ffffffc0feff3bf0
[  167.003985] x1 : ffffffc0db7a8e00 x0 : 0000000000000027
[  167.003991] ---[ end trace e3420ef78cf6360b ]---
[  167.008596] Call trace:
[  167.008600] [<ffffff800829bee4>] __brelse+0x4c/0x58
[  167.008604] [<ffffff800829c2a0>] bh_lru_install+0x120/0x1a0
[  167.008608] [<ffffff800829c4ec>] __find_get_block+0x1cc/0x1d8
[  167.008611] [<ffffff800829cffc>] __getblk_gfp+0x3c/0x348
[  167.008617] [<ffffff8008362390>] squashfs_bio_submit+0xe8/0x4f0
[  167.008621] [<ffffff8008362cb0>] __squashfs_read_data+0x160/0x268
[  167.008624] [<ffffff8008362ef4>] squashfs_read_data_async+0x4c/0x60
[  167.008628] [<ffffff80083673fc>] squashfs_readpages_block+0x1e4/0x3d8
[  167.008632] [<ffffff8008364c70>] __squashfs_readpages.isra.5+0x668/0x980
[  167.008635] [<ffffff8008364fc4>] squashfs_readpages+0x3c/0x78
[  167.008641] [<ffffff80081d47ec>] __do_page_cache_readahead+0x1ac/0x2a8
[  167.008646] [<ffffff80081c5bdc>] filemap_fault+0x2a4/0x6f0
[  167.008650] [<ffffff80081fcc78>] __do_fault+0x90/0x1d0
[  167.008655] [<ffffff80082017bc>] do_fault+0x25c/0x838
[  167.008659] [<ffffff8008203254>] handle_mm_fault+0x3f4/0x5f0
[  167.008663] [<ffffff80080a246c>] do_page_fault+0x254/0x480
[  167.008667] [<ffffff80080a2704>] do_translation_fault+0x6c/0x80
[  167.008671] [<ffffff8008080954>] do_mem_abort+0x54/0xb0
[  167.008674] [<ffffff8008080a7c>] do_el0_ia_bp_hardening+0x84/0x98
[  167.008678] [<ffffff8008083424>] el0_ia+0x18/0x1c
[  167.095223] VFS: brelse: Trying to free free buffer
[  167.100131] ------------[ cut here ]------------
[  167.104746] WARNING: CPU: 2 PID: 7557 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/fs/buffer.c:1197 __brelse+0x4c/0x58
[  167.116110] Modules linked in: bnep xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype fuse iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack br_netfilter zram overlay r8188eu(C) cfg80211 userspace_alert uvcvideo nvgpu ip_tables x_tables
[  167.116164] CPU: 2 PID: 7557 Comm: clang Tainted: G        WC      4.9.253-tegra #1
[  167.116167] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[  167.116171] task: ffffffc0db7a8e00 task.stack: ffffffc0b9c50000
[  167.116174] PC is at __brelse+0x4c/0x58
[  167.116178] LR is at __brelse+0x4c/0x58
[  167.116181] pc : [<ffffff800829bee4>] lr : [<ffffff800829bee4>] pstate: 40400045
[  167.116183] sp : ffffffc0b9c53660
[  167.116186] x29: ffffffc0b9c53660 x28: ffffffc0bb409740
[  167.116192] x27: 0000000000000003 x26: ffffffc0c480cc80
[  167.116198] x25: ffffffc0b9c536d0 x24: ffffffc09a358ea0
[  167.116203] x23: ffffff8009841488 x22: ffffff8009841408
[  167.116208] x21: ffffffc09a359068 x20: 0000000000000010
[  167.116213] x19: ffffffc09a358ea0 x18: 0000000000000010
[  167.116218] x17: 0000000000000000 x16: 0000000000000000
[  167.116223] x15: ffffffffffffffff x14: ffffff808a16e5b7
[  167.116227] x13: ffffff800a16e5c5 x12: 0000000000000000
[  167.116232] x11: 0000000005f5e0ff x10: 00000000000003c5
[  167.116237] x9 : 00000000ffffffd0 x8 : ffffff80083d7080
[  167.116242] x7 : ffffff8009ed44a8 x6 : ffffffc0feff3bf0
[  167.116246] x5 : ffffffc0feff3bf0 x4 : 0000000000000000
[  167.116251] x3 : ffffffc0feff97f8 x2 : ffffffc0feff3bf0
[  167.116255] x1 : ffffffc0db7a8e00 x0 : 0000000000000027
[  167.116262] ---[ end trace e3420ef78cf6360c ]---
[  167.120866] Call trace:
[  167.120870] [<ffffff800829bee4>] __brelse+0x4c/0x58
[  167.120874] [<ffffff800829c2a0>] bh_lru_install+0x120/0x1a0
[  167.120878] [<ffffff800829c4ec>] __find_get_block+0x1cc/0x1d8
[  167.120881] [<ffffff800829cffc>] __getblk_gfp+0x3c/0x348
[  167.120887] [<ffffff8008362390>] squashfs_bio_submit+0xe8/0x4f0
[  167.120890] [<ffffff8008362a40>] squashfs_process_blocks+0x2a8/0x388
[  167.120894] [<ffffff8008362744>] squashfs_bio_submit+0x49c/0x4f0
[  167.120897] [<ffffff8008362c20>] __squashfs_read_data+0xd0/0x268
[  167.120900] [<ffffff8008362e94>] squashfs_read_data+0x4c/0x60
[  167.120903] [<ffffff80083632c8>] squashfs_cache_get+0x138/0x308
[  167.120907] [<ffffff8008363888>] squashfs_read_metadata+0xa8/0x190
[  167.120910] [<ffffff8008365f90>] squashfs_lookup+0x1e8/0x3f8
[  167.120916] [<ffffff800826d128>] do_last+0x9a0/0xfa0
[  167.120920] [<ffffff800826d7b8>] path_openat+0x90/0x378
[  167.120924] [<ffffff800826ed28>] do_filp_open+0x70/0xe8
[  167.120928] [<ffffff8008259b4c>] do_sys_open+0x174/0x258
[  167.120931] [<ffffff8008259cb4>] SyS_openat+0x3c/0x50
[  167.120936] [<ffffff8008083900>] el0_svc_naked+0x34/0x38
[  167.128813] Unable to handle kernel paging request at virtual address 100000000061
[  167.129636] VFS: brelse: Trying to free free buffer
[  167.129649] ------------[ cut here ]------------
[  167.129658] WARNING: CPU: 1 PID: 7556 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/fs/buffer.c:1197 __brelse+0x4c/0x58
[  167.129685] Modules linked in: bnep xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype fuse iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack br_netfilter zram overlay r8188eu(C) cfg80211 userspace_alert uvcvideo nvgpu ip_tables x_tables
[  167.129690] CPU: 1 PID: 7556 Comm: clang Tainted: G        WC      4.9.253-tegra #1
[  167.129692] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[  167.129694] task: ffffffc0c97f8e00 task.stack: ffffffc0b9c58000
[  167.129697] PC is at __brelse+0x4c/0x58
[  167.129699] LR is at __brelse+0x4c/0x58
[  167.129701] pc : [<ffffff800829bee4>] lr : [<ffffff800829bee4>] pstate: 20400045
[  167.129702] sp : ffffffc0b9c5b610
[  167.129706] x29: ffffffc0b9c5b610 x28: ffffffc0e6d4ba00
[  167.129710] x27: 0000000000000001 x26: ffffffc0de409580
[  167.129713] x25: ffffffc0b9c5b680 x24: ffffffc09a34c5b0
[  167.129716] x23: ffffff8009841488 x22: ffffff8009841408
[  167.129719] x21: ffffffc09a34c8f0 x20: 0000000000000010
[  167.129721] x19: ffffffc09a34c5b0 x18: 0000007f98e11a70
[  167.129724] x17: 0000000000000002 x16: 0000000000000000
[  167.129727] x15: 0000000000000000 x14: ffffffc0ba284820
[  167.129730] x13: ffffffc0ba2847b8 x12: ffffff8009ea4000
[  167.129733] x11: 0000000000000000 x10: ffffff800a16e000
[  167.129735] x9 : 0000000000000000 x8 : ffffffc0fefb3e3b
[  167.129738] x7 : 0000000000000000 x6 : 0000000014ea8c73
[  167.129741] x5 : 0000000000000000 x4 : 0000000000000000
[  167.129743] x3 : ffffffffffffffff x2 : 00000040f57a1000
[  167.129746] x1 : ffffffc0c97f8e00 x0 : 0000000000000027
[  167.129748] ---[ end trace e3420ef78cf6360d ]---
[  167.129750] Call trace:
[  167.129753] [<ffffff800829bee4>] __brelse+0x4c/0x58
[  167.129756] [<ffffff800829c2a0>] bh_lru_install+0x120/0x1a0
[  167.129758] [<ffffff800829c4ec>] __find_get_block+0x1cc/0x1d8
[  167.129761] [<ffffff800829cffc>] __getblk_gfp+0x3c/0x348
[  167.129765] [<ffffff8008362390>] squashfs_bio_submit+0xe8/0x4f0
[  167.129767] [<ffffff8008362a40>] squashfs_process_blocks+0x2a8/0x388
[  167.129770] [<ffffff8008362744>] squashfs_bio_submit+0x49c/0x4f0
[  167.129772] [<ffffff8008362c20>] __squashfs_read_data+0xd0/0x268
[  167.129774] [<ffffff8008362e94>] squashfs_read_data+0x4c/0x60
[  167.129776] [<ffffff80083632c8>] squashfs_cache_get+0x138/0x308
[  167.129778] [<ffffff8008363888>] squashfs_read_metadata+0xa8/0x190
[  167.129781] [<ffffff8008365f90>] squashfs_lookup+0x1e8/0x3f8
[  167.129785] [<ffffff8008267ff0>] lookup_slow+0x98/0x160
[  167.129788] [<ffffff800826b7f0>] walk_component+0x1b8/0x2f8
[  167.129791] [<ffffff800826bf6c>] path_lookupat+0x9c/0x148
[  167.129794] [<ffffff800826e0b0>] filename_lookup+0x88/0x150
[  167.129796] [<ffffff800826e290>] user_path_at_empty+0x58/0x70
[  167.129799] [<ffffff8008261f20>] vfs_fstatat+0x68/0xc0
[  167.129801] [<ffffff800826233c>] SyS_newfstatat+0x3c/0x60
[  167.129805] [<ffffff8008083900>] el0_svc_naked+0x34/0x38
[  167.162564] Mem abort info:
[  167.165351]   ESR = 0x96000021
[  167.174801]   Exception class = DABT (current EL), IL = 32 bits
[  167.180975]   SET = 0, FnV = 0
[  167.184269]   EA = 0, S1PTW = 0
[  167.187683] Data abort info:
[  167.190805]   ISV = 0, ISS = 0x00000021
[  167.194975]   CM = 0, WnR = 0
[  167.198139] [0000100000000061] address between user and kernel address ranges
[  167.205471] Internal error: Oops: 96000021 [#1] PREEMPT SMP
[  167.211035] Modules linked in: bnep xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype fuse iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack br_netfilter zram overlay r8188eu(C) cfg80211 userspace_alert uvcvideo nvgpu ip_tables x_tables
[  167.239602] CPU: 2 PID: 639 Comm: kworker/2:1 Tainted: G        WC      4.9.253-tegra #1
[  167.247674] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[  167.253674] Workqueue: events read_wq_handler
[  167.258028] task: ffffffc0f934e200 task.stack: ffffffc0f9788000
[  167.263936] PC is at __ll_sc_atomic_sub+0x4/0x18
[  167.268543] LR is at squashfs_bh_to_actor+0x1d8/0x200
[  167.273581] pc : [<ffffff8008456f44>] lr : [<ffffff8008367ae8>] pstate: 20400045
[  167.280959] sp : ffffffc0f978bc60
[  167.284262] x29: ffffffc0f978bc60 x28: 0000000000000000
[  167.289575] x27: 000000000000003c x26: 0000000000000000
[  167.294889] x25: 0000000000000000 x24: 0000000000000400
[  167.300204] x23: ffffffc0bb409f00 x22: ffffffc0c480cc80
[  167.305516] x21: 000000000000001f x20: 0000000000000000
[  167.310830] x19: 000000000000001f x18: 0000007f9dd24a70
[  167.316141] x17: 0000000058554e48 x16: 0000000000000000
[  167.321452] x15: 00000000000000bd x14: 000000000000003e
[  167.326764] x13: 682e73657079742f x12: 6d73612f756e672d
[  167.332076] x11: 0000000000000400 x10: 0000000000000a10
[  167.337388] x9 : ffffffc0f978bd10 x8 : ffffffc0f934ec70
[  167.342699] x7 : 0000000000000400 x6 : 0000000000000400
[  167.348010] x5 : 0000000000000400 x4 : 0000000000000004
[  167.353322] x3 : 0000000000000002 x2 : 0000100000000001
[  167.358635] x1 : 0000100000000061 x0 : 0000000000000001
[  167.365432] Process kworker/2:1 (pid: 639, stack limit = 0xffffffc0f9788000)
[  167.372462] Call trace:
[  167.374904] [<ffffff8008456f44>] __ll_sc_atomic_sub+0x4/0x18
[  167.380551] [<ffffff8008362a60>] squashfs_process_blocks+0x2c8/0x388
[  167.386889] [<ffffff8008362b40>] read_wq_handler+0x20/0x30
[  167.392364] [<ffffff80080d40cc>] process_one_work+0x1e4/0x4b0
[  167.398097] [<ffffff80080d43e8>] worker_thread+0x50/0x4c8
[  167.403484] [<ffffff80080db0bc>] kthread+0xec/0xf0
[  167.408263] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
[  167.413564] ---[ end trace e3420ef78cf6360e ]---
client_loop: send disconnect: Broken pipe
matsuzawa@tmatsuzawa-nano2:~$ dmesg | more
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5494-d8000) (gcc version 7.3.1
 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3
-2018.05) ) #1 SMP PREEMPT Wed Apr 20 14:25:12 PDT 2022
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] Found tegra_fbmem: 00800000@92ca9000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveou
t
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carve
out
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] On node 0 totalpages: 1039872
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519168 pages, LIFO batch:31
[    0.000000]   Normal zone: 8136 pages used for memmap
[    0.000000]   Normal zone: 520704 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[    0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=
0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb
no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0
x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_e
dp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1  earlycon=uart8250,mmio32,0
x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 f
bcon=map:0 net.ifnames=0 quiet root=/dev/sda1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8
 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
We don’t have experience about this. Would need other users to check and give suggestion.
FYI. I am seeing this on SD card boot as well (so not specific to USB drive).
Repro step:
(on 1st terminal)
$ dmesg --follow
(on 2nd terminal)
$ sudo snap install flutter --classic
$ flutter create myapp
$ cd myapp
$ flutter build linux --debug -v
Related to snap/squashfs?
squashfs name appearing in the stack traces above, and snapd is using squashfs.
$ df -T
Filesystem     Type     1K-blocks     Used Available Use% Mounted on
/dev/sda1      ext4     492113928 41262668 430697868   9% /
none           devtmpfs   1780168        0   1780168   0% /dev
tmpfs          tmpfs      2025552        4   2025548   1% /dev/shm
tmpfs          tmpfs      2025552    20308   2005244   2% /run
tmpfs          tmpfs         5120        4      5116   1% /run/lock
tmpfs          tmpfs      2025552        0   2025552   0% /sys/fs/cgroup
/dev/loop0     squashfs     50304    50304         0 100% /snap/core18/2542
/dev/loop1     squashfs     41728    41728         0 100% /snap/snapd/16299
/dev/loop2     squashfs    171264   171264         0 100% /snap/flutter/124
tmpfs          tmpfs       405108       16    405092   1% /run/user/120
tmpfs          tmpfs       405108        0    405108   0% /run/user/1000
Without using snap (instead, just git clone and build tools), there is no error described above.
So, the issue is with snap/squashfs.
