I’m testing RS-485 on Jetson Nano and I have some questions
The Jetson Nano has the ttyTHS1 and ttyTHS2 for RS-485
I tried to transmit message from THS1 to THS2, but the messages only showed 15 words
The 16th exceed words and even over will be showed as garbled characters
This situation did not happened when I transmit message from THS2 to THS1
What is the reason for this?
And is it normal for RS-485 function?
I have found the similar issue for this
After I set the baud rate to 57600(my origin setting is 115200), the garbled characters disappear
Is there any possible baud in 115200 and there’s no garbled characters?
hello zax0220jecht,
please have a try to disable getty service,
$ sudo systemctl stop nvgetty.service
$ sudo systemctl disable nvgetty.service
and, use the commands to have getty service running in the background manually.
$ sudo /sbin/getty -a ubuntu -L 115200 ttyTHS<port> &
Hi Jerry,
I used the command to check the service is using or not, but there’s no process using this service
$ sudo ps aux | grep nvgetty
What is the function of command you offered?
$ sudo /sbin/getty -a ubuntu -L 115200 ttyTHS &
Hi
I have another question
Is Jetson Nano serial port support the speed up to 115200?
I have check the kernel souce code and saw the correspond baud rate setting
But I can’t set 115200 baud and transmit message successfully
Only if the 57600 baud can work
hello zax0220jecht,
the default bardrate is 115200/8n1 for UART console.
Hi Jerry,
I found the route cause in the dts
I comment out these two lines in platform by reference the dts of soc and it works normally without garbled characters
platform
soc
Thanks for your great help
system
Closed
#10
