Environment:
jetson-nano-sd-card-image-r32.3.1
deepstream_sdk_v4.0.1_jetson.tbz2
install DS SDK follow this page:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/index.html
when I run the command
cd ./deepstream_sdk_v4.0.1_jetson/samples/configs/deepstream-app
deepstream-app -c source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
got fail info
** ERROR: <create_osd_bin:40>: Failed to create 'osd_conv'
** ERROR: <create_osd_bin:114>: create_osd_bin failed
** ERROR: <create_processing_instance:705>: create_processing_instance failed
** ERROR: <create_pipeline:1045>: create_pipeline failed
** ERROR: <main:632>: Failed to create pipeline
Quitting
App run failed
and then i disable the plugin ‘osd’, run again
Unable to set device in gst_nvstreammux_change_state
** ERROR: <main:651>: Failed to set pipeline to PAUSED
Quitting
App run failed
finally i disable the plugin ‘streammux’
the the video runs without track abilities.
How to fix this problem? Appreciate it!
