Jetson Nano SDK Flashing Process Stalled – Need Assistance
My issue is that when I first used my Jetson Nano, I used Balena to flash the system onto the SD card using the Orin version. Strangely enough, it worked normally. However, when prompted to update the system, I clicked the update, and the system then failed to boot. I later discovered that I had downloaded the wrong system image. I subsequently flashed the correct image, but the Jetson Nano continued to show that it could not recognize the SD card—even after trying three different SD cards. Later, I attempted to flash the device using the SDK and re-downloaded the system image. I used both a VM and an Ubuntu virtual machine for the SDK flashing, but the SDK Manager remains stuck at Step 3. Initially, it would occasionally report an IP issue, but later it stopped showing that, and the progress has been stuck at 30.77%. What should I do now?
The issue you posted at Jetson Nano forum, are you using Orin Nano or Jetson Nano?
jetsonnano, I have solved it ,the problem is dbt problem, and the mec problem
