Hi everyone,
I got a jetson nano dev kit with correct adapter and fan installed, but after power on, it will shutdown suddenly after running for around 10 minutes, and restart itself. Anyone know what could be the problem?
Hi everyone,
Are you running any application when it restarts?
The system has deepstream and azure iot edge runtime installed, and will be running when it restarts. My colleague has same devices and software, theirs are running well.
the adapter is bought from US and I am using it in China, does this matter?
Hi tiliu,
You could try to borrow the adapter and cable from your colleague to test if that’s the cause.
