I successfully installed the python snap7 library via
pip3 install python-snap7
I can import the snap 7 library with no problem as its installed and hives no error.
how ever when I try to connect connect to the PLC,
import snap7.client as c
snap7.exception.snap7 Exception : can’t find snap7 library. if installed,try running ldconfig
Maybe the python version. Check install the snap7 is for python2 or python3
It is for python 3 ,I have used it in Ubuntu 20 with python 3.
I check without problem. What’s you JetPack version?
python3-pip is already the newest version (9.0.1-2.3~ubuntu1.18.04.5).
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common kde-window-manager kinit kio kpackagetool5
kwayland-data kwin-common kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5 libkdecorations2private5v5 libkf5activities5 libkf5attica5 libkf5completion-data
libkf5completion5 libkf5declarative-data libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5 libkf5idletime5
libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5
libkf5package-data libkf5package5 libkf5plasma5 libkf5quickaddons5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data
libkf5textwidgets5 libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5 libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5 libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediaquick-p5 libqt5multimediawidgets5
libqt5opengl5 libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5test5 libqt5webchannel5 libqt5webkit5
libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia qml-module-qtquick2 rdate tasksel tasksel-data
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 418 not upgraded.
nvidia@nvidia-desktop:~$ pip3 install python-snap7
Collecting python-snap7
Downloading https://files.pythonhosted.org/packages/3c/14/bba7e95a336c075fe74d69d649d46268016ccde9814fba021a15dde4c49a/python-snap7-1.1.tar.gz (43kB)
100% |████████████████████████████████| 51kB 278kB/s
Building wheels for collected packages: python-snap7
Running setup.py bdist_wheel for python-snap7 ... done
Stored in directory: /home/nvidia/.cache/pip/wheels/79/72/eb/1dc8569bd4dc6472e0a6d75415ad0184ce0384c29becd0ce7d
Successfully built python-snap7
Installing collected packages: python-snap7
Successfully installed python-snap7-1.1
nvidia@nvidia-desktop:~$ pyton3
-bash: pyton3: command not found
nvidia@nvidia-desktop:~$ python3
Python 3.6.9 (default, Jan 26 2021, 15:33:00)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
I was able to get to do all the above steps listed above , but when i try to run the client ,It says that
JETPACK is 4.6.0
As mentioned in my question
Please run these commands
c.Client()
And if it still works then let me know as i have not able to make it work
I have the same problem like @hamzashah411411 . Yes, snap7 successfully installing but after the installation, when I am running the snap7.client.Client()
or c.Client()
commands, the snap7.exception.snap7 Exception : can’t find snap7 library. if installed,try running ldconfig
error shows up.
I don’t really understand how people use snap7 on Jetson. Because there is no jetson or ARM v8 support on this site . However, I saw some videos that show snap7 works on Jetson nano.
So, can anyone tell us how to deal with this issue?
Only a specific version of the snap 7 python library works.
Once you pip install that you have to copy paste a file for snap 7 repository to the system path and then it will work.
Unfortunately (for you , not for me) I am on vacation and don’t have a nano with me otherwise I would have mentioned the exact version , file and it’s path to make it work.
Its very simple solution but I banged my head around for days for that.
For only I can only tell you that it works as I don’t even have work laptop with me for now.
GOOD LUCK!
Looks like you need install snap7 also not just pyton-snap7
Try download the source code to install it.
https://python-snap7.readthedocs.io/en/latest/installation.html#snap7
system
Closed
November 4, 2021, 3:24am
11
