It show follow errors(/var/log/syslog) when occurred error:
Jun 2 21:19:05 LH-S100 nvargus-daemon[8207]: SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function assignAllBuffersFromStream(), line 230)
Jun 2 21:19:05 LH-S100 nvargus-daemon[8207]: SCF: Error Timeout: (propagating from src/components/stages/CCDataSetupStage.cpp, function doHandleRequest(), line 68)
Jun 2 21:19:05 LH-S100 nvargus-daemon[8207]: SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
Jun 2 21:19:05 LH-S100 nvargus-daemon[8207]: SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
Jun 2 21:19:05 LH-S100 nvargus-daemon[8207]: SCF: Error InvalidState: Session has suffered a critical failure (in src/api/Session.cpp, function capture(), line 667)
Jun 2 21:19:05 LH-S100 nvargus-daemon[8207]: (Argus) Error InvalidState: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
And, I found some errors about nvargus-daemo in the /var/log/syslog file when start gstreamer.
Jun 2 21:02:18 LH-S100 nvargus-daemon[4989]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections…=== P_LH_S100[7928]: Connection established (7FA32A91D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Jun 2 21:02:19 LH-S100 nvargus-daemon[4989]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jun 2 21:02:19 LH-S100 nvargus-daemon[4989]: ---- imager: No override file found. ----
Jun 2 21:02:19 LH-S100 nvargus-daemon[4989]: LSC: LSC surface is not based on full res!
Jun 2 21:02:19 LH-S100 nvargus-daemon[4989]: === P_LH_S100[7928]: CameraProvider initialized (0x7f9c835120)LSC: LSC surface is not based on full res!
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: === P_LH_S100[7928]: Connection closed (7FA32A91D0)=== P_LH_S100[7928]: WARNING: CameraProvider was not destroyed before client connection terminated.=== P_LH_S100[7928]: The client may have abnormally terminated. Destroying CameraProvider…=== P_LH_S100[7928]: CameraProvider destroyed (0x7f9c835120)=== P_LH_S100[7928]: WARNING: Cleaning up 1 outstanding requests…=== P_LH_S100[7928]: WARNING: Cleaning up 1 outstanding streams…SCF: Error InvalidState: 5 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 305)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function ~EGLStreamProducer(), line 50)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: === P_LH_S100[7928]: WARNING: Cleaning up 1 outstanding stream settings…=== P_LH_S100[7928]: WARNING: Cleaning up 1 outstanding sessions…(NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:497) (in Mutex.cpp, function lock(), line 79)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: SCF: Error BadParameter: Buffer is not pending (in src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 501)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: (NvCameraUtils) Error InvalidState: Mutex has not been initialized (in Mutex.cpp, function unlock(), line 88)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: SCF: Error BadParameter: (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBuffer(), line 486)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: SCF: Error BadParameter: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 447)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: SCF: Error BadParameter: (propagating from src/components/stages/BufferReturnStage.h, function doExecute(), line 43)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: SCF: Error BadParameter: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: (NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:497) (in Mutex.cpp, function lock(), line 79)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: (NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:533) (in Mutex.cpp, function lock(), line 79)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: SCF: Error BadParameter: (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 538)
Jun 2 21:02:27 LH-S100 nvargus-daemon[4989]: (NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:551) (in Mutex.cpp, function lock(), line 79)
Jun 2 21:02:28 LH-S100 nvargus-daemon[4989]: (NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:497) (in Mutex.cpp, function lock(), line 79)
Jun 2 21:02:28 LH-S100 nvargus-daemon[4989]: (NvCameraUtils) Error InvalidState: Mutex has not been initialized (in Mutex.cpp, function unlock(), line 88)
Jun 2 21:02:28 LH-S100 nvargus-daemon[4989]: (NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:533) (in Mutex.cpp, function lock(), line 79)
Jun 2 21:02:28 LH-S100 nvargus-daemon[4989]: SCF: Error BadParameter: (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 538)
Jun 2 21:02:28 LH-S100 nvargus-daemon[4989]: (NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:551) (in Mutex.cpp, function lock(), line 79)
Jun 2 21:02:32 LH-S100 nvargus-daemon[4989]: waitForIdleLocked remaining request 234
Jun 2 21:02:32 LH-S100 nvargus-daemon[4989]: waitForIdleLocked remaining request 233
Jun 2 21:02:32 LH-S100 nvargus-daemon[4989]: waitForIdleLocked remaining request 232
Jun 2 21:02:32 LH-S100 nvargus-daemon[4989]: waitForIdleLocked remaining request 231
Jun 2 21:02:32 LH-S100 nvargus-daemon[4989]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 920)
Jun 2 21:02:32 LH-S100 nvargus-daemon[4989]: (Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function destroy(), line 166)
Jun 2 21:02:34 LH-S100 pulseaudio[8176]: Daemon already running.
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: waitForIdleLocked remaining request 234
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: waitForIdleLocked remaining request 233
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: waitForIdleLocked remaining request 232
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: waitForIdleLocked remaining request 231
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 920)
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: SCF: Error Timeout: (propagating from src/api/Session.cpp, function abortCaptures(), line 886)
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: SCF: Error Timeout: (propagating from src/api/Session.cpp, function shutdown(), line 400)
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: PowerServiceCore:handleRequests: timePassed = 5090
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: SCF: Error Timeout: (propagating from src/api/Session.cpp, function shutdown(), line 500)
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: SCF: Error Timeout: (propagating from src/api/CameraDriver.cpp, function deleteSession(), line 619)
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: (Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function destroy(), line 191)
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: === P_LH_S100[7928]: NOTE: Destroy all libargus objects before destroying the CameraProvider to avoid these warnings.FiberScheduler: 4 fibers still exist!
Jun 2 21:02:37 LH-S100 nvargus-daemon[4989]: === P_LH_S100[7928]: Connection cleaned up (7FA32A91D0)free(): invalid size
Jun 2 21:02:38 LH-S100 systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=6/ABRT
Jun 2 21:02:38 LH-S100 systemd[1]: nvargus-daemon.service: Failed with result ‘signal’.
Jun 2 21:02:38 LH-S100 systemd[1]: nvargus-daemon.service: Service hold-off time over, scheduling restart.
Jun 2 21:02:38 LH-S100 systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 1.
Jun 2 21:02:38 LH-S100 systemd[1]: Stopped Argus daemon.
Jun 2 21:02:38 LH-S100 systemd[1]: Started Argus daemon.
Jun 2 21:02:47 LH-S100 nvargus-daemon[8207]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections…=== P_LH_S100[8253]: Connection established (7F7A7F01D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Jun 2 21:02:47 LH-S100 nvargus-daemon[8207]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jun 2 21:02:47 LH-S100 nvargus-daemon[8207]: ---- imager: No override file found. ----
Jun 2 21:02:47 LH-S100 nvargus-daemon[8207]: LSC: LSC surface is not based on full res!
Jun 2 21:02:48 LH-S100 nvargus-daemon[8207]: === P_LH_S100[8253]: CameraProvider initialized (0x7f74836010)LSC: LSC surface is not based on full res!
