Jetson Nano - SPI/CAN MCP2515
Hello! I’ve been following topics about using the MCP2515 integration with the Jetson Nano devkit, but I have not been able to make it work yet. I’d like to kindly ask for some guidance. I believe the missing step is removing the GPIO from the device tree for the selected SPI pins. Could someone please let me know what needs to be changed in the a02 device tree? (/dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts)
Notes::
SPI loopback test ok!
sudo ./spidev_test -D /dev/spidev0.0 -v -p “HelloWorld123456789abcdef”
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
TX | 48 65 6C 6C 6F 57 6F 72 6C 64 31 32 33 34 35 36 37 38 39 61 62 63 64 65 66 __ __ __ __ __ __ __ | HelloWorld123456789abcdef
RX | 48 65 6C 6C 6F 57 6F 72 6C 64 31 32 33 34 35 36 37 38 39 61 62 63 64 65 66 __ __ __ __ __ __ __ | HelloWorld123456789abcdef
JetsionIO:
Actions implemented:
Clone the Seeed-Studio github repository as stated by andrew_h above from GitHub - Seeed-Studio/seeed-linux-dtoverlays: Device Tree Overlays for Seeed boards
Download the dts file here and save it to seeed-linux-dtoverlays-master/overlays/jetsonnano
In the folder seeed-linux-dtoverlays-master run “make all_jetsonnano”
Remove the existing overlays in /boot - I got a conflict that prevented me from running jetson-io when both files were still present
“sudo rm /boot/tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo”
“sudo rm /boot/tegra210-p3448-0000-p3449-0000-a02-mcp251x.dtbo”
Copy the generated jetson-mcp251x.dtbo file from seeed-linux-dtoverlays-master/overlays/jetsonnano into /boot/
Run jetson-io and configure for MCP251x
I did not see an option for selecting the hardware MCP251x for some reason
jetson_release
Software part of jetson-stats 4.1.0 - (c) 2023, Raffaello Bonghi
Model: NVIDIA Jetson Nano Developer Kit - Jetpack 4.6.3 [L4T 32.7.3]
NV Power Mode: 5W - Type: 1
jtop:
  • Version: 4.1.0
  • Service: Active
Libraries:
  • CUDA: 10.2.300
cat /proc/device-tree/nvidia,dtsfilename
cat extlinux.conf
TIMEOUT 30
DEFAULT JetsonIO
MENU TITLE L4T boot options
LABEL stock
MENU LABEL stock kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
LABEL custom_overclock
MENU LABEL custom_overclock
LINUX /boot/Image-overclock
INITRD /boot/initrd
When testing a custom kernel, it is recommended that you create a backup of
the original kernel and add a new entry to this file so that the device can
fallback to the original kernel. To do this:
1, Make a backup of the original kernel
sudo cp /boot/Image /boot/Image.backup
2, Copy your custom kernel into /boot/Image
3, Uncomment below menu setting lines for the original kernel
4, Reboot
LABEL backup
MENU LABEL backup kernel
LINUX /boot/Image.backup
INITRD /boot/initrd
APPEND ${cbootargs}
LABEL JetsonIO
MENU LABEL Custom Header Config: <HDR40 User Custom [2024-11-13-154632]>
FDT /boot/kernel_tegra210-p3448-0000-p3449-0000-a02-user-custom.dtb
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 overlays=jetson-mcp251x
