Jetson nano SPI + CUDA
How to enable jetson nano spi1 and cuda at the same time for jetson nano 4GB ?
I use “sudo /opt/nvidia/jetson-io/jetson-io.py” ,but it not work referrint to "generic-no-api-public_r2
Do you know ? How to do it ?
Hi Beenn,
Are you using the devkit or custom board for Jetson Nano?
SPI and CUDA seem different feature on Jetson Nano and they are not related.
For SPI, have you tried using Jetson-IO to enable SPI successfully?
For CUDA, have you installed nvidia-jetpack?
I think that jetpack is 4.6.1 and my device is jetson nano. Additionally my cuda is 10.2.
No, it seems you are using Jetpack 4.6.3(L4T r32.7.3).
I know that you are using Jetson Nano, but is the module on the devkit board or custom carrier board?
(i.e. where did you get this board? or the carrier board is designed by yourself?)
you are right. I am using jetpack 4.6.3 and having copying a new system from other jetson nano’s sd card. This jetson nano busied from taobao isn’t designed.
Could you check with your vendor to know if it is our official devkit or the 3rd-party custom carrier board?
If you are using our official devkit, jetson-io tool should work.
Please share the full steps and the results how did you use this tool.
