elhe
January 10, 2022, 8:47am
1
I am currently looking into how to set-up the Jetson Nano as a SPI slave device.
The most current forum post on this topic I could find was from over 2 years ago.
What is currently the preferred way to set-up SPI slave on Jetson Nano.
You can use jetson-io to configure the pinmux and modify dump the dtb from the system and modify the SPI as slave mode.
elhe
January 11, 2022, 6:04am
4
įŗhich of these attributes is the mode?
spi@7000d600 {
compatible = "nvidia,tegra210-spi";
reg = <0x00000000 0x7000d600 0x00000000 0x00000200>;
interrupts = <0x00000000 0x00000052 0x00000004>;
iommus = <0x00000030 0x0000000e>;
#address-cells = <0x00000001>;
#size-cells = <0x00000000>;
dmas = <0x00000051 0x00000010 0x00000051 0x00000010>;
dma-names = "rx", "tx";
nvidia,clk-parents = "pll_p", "clk_m";
clocks = <0x00000026 0x0000002c 0x00000026 0x000000f3 0x00000026 0x000000e9>;
clock-names = "spi", "pll_p", "clk_m";
resets = <0x00000026 0x0000002c>;
reset-names = "spi";
status = "okay";
linux,phandle = <0x00000111>;
prod-settings {
#prod-cells = <0x00000003>;
prod {
prod = <0x00000004 0x00000fff 0x00000000>;
prod_c_flash {
status = "disabled";
prod = <0x00000004 0x0000003f 0x00000006>;
prod_c_loop {
prod = <0x00000004 0x00000fff 0x0000044b>;
spi@0 {
compatible = "spidev";
reg = <0x00000000>;
spi-max-frequency = <0x01f78a40>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x00000006>;
spi@1 {
reg = <0x00000001>;
controller-data {
Is using fdtput equivalent to dumping the dtb and changing a attribute?
Use below command to dump the device tree and modify it as salve by modify ānvidia,tegra210-spiā to ānvidia,tegra210-spi-slaveā
sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
elhe
January 11, 2022, 12:27pm
6
Thanks for the answer @ShaneCCC which dtb do I replace with my customized one?
/boot/dtb/
kernel_tegra210_p3448-0000-p3449-0000-b00.dtb
or
/boot/tegra210-p3448-0000-p3449-0000-b00.dtb
cat /sys/firmware/devicetree/base/compatible
Shows the following:
nvidia,p3449-0000-b00+p3448-0000-b00nvidia,jetson-nanonvidia,tegra210
Check the /boot/extlinux/extlinux.conf to know the file to replace.
system
Closed
February 2, 2022, 5:30am
10
