Jetson nano startup screen imx219_board_setup: error during i2c read probe(-121)
jetson nano startup screen imx219_board_setup: error during i2c read probe(-121),imx219 board setup failed,jetson nano imx219 cheese no device found!
That’s tells the HW have problem to detect the sensor. Maybe the module not the Pi V2 or the cable have problem.
What’s the below command show.
v4l2-ctl --list-devices
Install the v4l-utils first.
sudo apt-get install v4l-utils
The first line for device at 7-0010
imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
is not followed by an error message. This camera has been successuflly probed and can be used.
The next lines with device at 8-0010 show that probing that device failed. This is normal if you have only one camera connected in CSI0 connector.
thanks!
Also please run the nvgstcapture-1.0 or argus_camera instead of using cheese.
Current not support bayer sensor for cheese.
I ran gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink and got:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21,000000 fps Duration = 47619048 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28,000001 fps Duration = 35714284 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
… and it keeps stopped without any image/video displayed and no more feedback from terminal shell.
Then, I tryed Preformatted text and got pretty the same result:
Encoder null, cannot set bitrate!
Encoder Profile = High
Supported resolutions in case of ARGUS Camera
  (2) : 640x480
  (3) : 1280x720
  (4) : 1920x1080
  (5) : 2104x1560
  (6) : 2592x1944
  (7) : 2616x1472
  (8) : 3840x2160
  (9) : 3896x2192
  (10): 4208x3120
  (11): 5632x3168
  (12): 5632x4224
Runtime ARGUS Camera Commands:
  Help : 'h'
  Quit : 'q'
  Set Capture Mode:
      mo:<val>
          (1): image
          (2): video
  Get Capture Mode:
      gmo
  Set sensor orientation:
      so:<val>
          (0): none
          (1): Rotate counter-clockwise 90 degrees
          (2): Rotate 180 degrees
          (3): Rotate clockwise 90 degrees
  Get sensor orientation:
      gso
  Set sensor mode:
      smo:<val> e.g., smo:1
  Get sensor mode:
      gsmo
  Set Whitebalance Mode:
      wb:<val>
          (0): off
          (1): auto
          (2): incandescent
          (3): fluorescent
          (4): warm-fluorescent
          (5): daylight
          (6): cloudy-daylight
          (7): twilight
          (8): shade
          (9): manual
  Get Whitebalance Mode:
      gwb
  Set Saturation (0 to 2):
      st:<val> e.g., st:1.25
  Get Saturation:
      gst
  Set Exposure Compensation (-2 to 2):
      ec:<val> e.g., ec:-2
  Get Exposure Compensation:
      gec
  Set Auto Whitebalance Lock:
      awbl:<val> e.g., awbl:0
  Get Auto Whitebalance Lock:
      awbl
  Set Auto Exposure Lock:
      ael:<val> e.g., ael:0
  Get Auto Exposure Lock:
      gael
  Set TNR Mode:
      tnrm:<val> e.g., tnrm:1
          (0): OFF
          (1): FAST
          (2): HIGH QUALITY
  Get TNR Mode:
      gtnrm
  Set TNR Strength (-1 to 1):
      tnrs:<val> e.g., tnrs:0.5
  Get TNR Strength:
      gtnrs
  Set EE Mode:
      eem:<val> e.g., eem:1
          (0): OFF
          (1): FAST
          (2): HIGH QUALITY
  Get EE Mode:
      geem
  Set EE Strength (-1 to 1):
      ees:<val> e.g., ees:0.5
  Get EE Strength:
      gees
  Set Auto Exposure Anti-Banding (0 to 3):
      aeab:<val> e.g., aeab:2
          (0): OFF
          (1): MODE AUTO
          (2): MODE 50HZ
          (3): MODE 60HZ
  Get Auto Exposure Anti-Banding:
      gaeab
  Set Gain Range:
      gr:<val><space><val> e.g., gr:1 16
  Get Gain Range:
      ggr
  Set Exposure Time Range:
      etr:<val><space><val> e.g., etr:34000 35000
  Get Exposure Time Range:
      getr
  Set ISP Digital Gain Range:
      dgr:<val><space><val> e.g., dgr:2 152
  Get ISP Digital Gain Range:
      gdgr
  Capture: enter 'j' OR
           followed by a timer (e.g., jx5000, capture after 5 seconds) OR
           followed by multishot count (e.g., j:6, capture 6 images)
           timer/multihot values are optional, capture defaults to single shot with timer=0s
  Start Recording : enter '1'
  Stop Recording  : enter '0'
  Video snapshot  : enter '2' (While recording video)
  Get Preview Resolution:
      gpcr
  Get Image Capture Resolution:
      gicr
  Get Video Capture Resolution:
      gvcr
Runtime encoder configuration options:
  Set Encoding Bit-rate(in bytes):
      br:<val> e.g., br:4000000
  Get Encoding Bit-rate(in bytes):
      gbr
  Set Encoding Profile(only for H.264):
      ep:<val> e.g., ep:1
          (0): Baseline
          (1): Main
          (2): High
  Get Encoding Profile(only for H.264):
      gep
  Force IDR Frame on video Encoder(only for H.264):
      Enter 'f'
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
** Message: 15:05:55.198: <main:4670> iterating capture loop ....
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
   Camera index = 0
   Camera mode  = 5
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
   Frame Rate = 120.000005
The output for gst-launch-1.0 nvarguscamerasrc report a error gst-launch-1.0 nvarguscamerasrc
and finish the command:
   Camera index = 0
   Camera mode  = 2
   seconds to Run    = 0
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason not-linked (-1)
Execution ended after 0:00:00.787245989
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
… where the error is:
The camera in port CAM0 is connected with Raspberry Pi Camera v2 and previously it worked. For any reason, i does not work now. The result of v4l2-ctl --list-devices is:
vi-output, imx219 7-0010 (platform:54080000.vi:0):
	/dev/video0
And the return of v4l2-ctl --all is:
Driver Info (not using libv4l2):
	Driver name   : tegra-video
	Card type     : vi-output, imx219 7-0010
	Bus info      : platform:54080000.vi:0
	Driver version: 4.9.201
	Capabilities  : 0x84200001
		Video Capture
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps   : 0x04200001
		Video Capture
		Streaming
		Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: no power)
Format Video Capture:
	Width/Height      : 1920/1080
	Pixel Format      : 'RG10'
	Field             : None
	Bytes per Line    : 3840
	Size Image        : 4147200
	Colorspace        : sRGB
	Transfer Function : Default (maps to sRGB)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Full Range)
	Flags             :
Camera Controls
                     group_hold 0x009a2003 (bool)   : default=0 value=0 flags=execute-on-write
                    sensor_mode 0x009a2008 (int64)  : min=0 max=0 step=0 default=0 value=2 flags=slider
                           gain 0x009a2009 (int64)  : min=0 max=0 step=0 default=0 value=16 flags=slider
                       exposure 0x009a200a (int64)  : min=0 max=0 step=0 default=0 value=33330 flags=slider
                     frame_rate 0x009a200b (int64)  : min=0 max=0 step=0 default=0 value=30000000 flags=slider
                    bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=1
                override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=1
                   height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                     size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
               write_isp_format 0x009a2068 (bool)   : default=0 value=0
       sensor_signal_properties 0x009a2069 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
        sensor_image_properties 0x009a206a (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
      sensor_control_properties 0x009a206b (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
              sensor_dv_timings 0x009a206c (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
               low_latency_mode 0x009a206d (bool)   : default=0 value=0
               preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=0
                   sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=6 flags=read-only
I tried too with another flex cable and with another Raspberry Pi Camera v2 and the result is the same.
I appreciate any help. Thanks
You may check this post.
check this
