[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1d0ae2
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.272] Invalid GPT Partition
[0000.287] Using BFS PT to query partitions
[0000.291] failed to load NvTbootTbootCpu from (2:0)
[0000.296] re-load NvTbootTbootCpu from (4:0)
[0000.551] Csd NumOfBlocks=250085376
[0000.610] Using GPT Primary to query partitions
[0000.618] Loading Tboot-CPU binary
[0000.995] Verifying TBC in OdmNonSecureSBK mode
[0001.005] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0001.012] Bootloader downloaded successfully.
[0001.016] Downloaded Tboot-CPU binary to 0xa0000258
[0001.021] MAX77620_GPIO5 configured
[0001.025] CPU power rail is up
[0001.028] CPU clock enabled
[0001.031] Performing RAM repair
[0001.034] Updating A64 Warmreset Address to 0xa00002e9
[0001.039] Loading NvTbootBootloaderDTB
[0002.348] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0002.410] Bootloader DTB Load Address: 0x83000000
[0002.415] Loading NvTbootKernelDTB
[0003.723] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0003.785] Kernel DTB Load Address: 0x83100000
[0003.793] Loading cboot binary
[0005.474] Verifying EBT in OdmNonSecureSBK mode
[0005.516] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0005.523] Bootloader downloaded successfully.
[0005.715] Using BFS PT to query partitions
[0005.719] Next binary entry address: 0x92c00258
[0005.724] BoardId: 3448
[0005.728] Overriding pmu board id with proc board id
[0005.733] Display board id is not available
[0007.229] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0007.282] /bpmp deleted
[0007.285] SC7EntryFw header found loaded at 0xff700000
[0007.476] OVR2 PMIC
[0007.478] Bpmp FW successfully loaded
[0007.494] WB0 init successfully at 0xff780000
[0007.498] Set NvDecSticky Bits
[0007.502] GSC2 address ff53fffc value c0edbbcc
[0007.508] GSC MC Settings done
[0007.514] TOS Image length 53680
[0007.517] Monitor size 53680
[0007.519] OS size 0
[0007.680] Secure Os AES-CMAC Verification Success!
[0007.685] TOS image cipher info: plaintext
[0007.689] Loading and Validation of Secure OS Successful
[0007.705] SC7 Entry Firmware - 0xff700000, 0x4000
[0007.709] NvTbootPackSdramParams: start.
[0007.715] NvTbootPackSdramParams: done.
[0007.718] Tegraboot started after 53275 us
[0007.722] Basic modules init took 5822233 us
[0007.726] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0007.732] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0007.737] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0007.743] Storage Device Read Time = 6730 ms, Read Size = 2306 KB
[0007.748] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0007.754] Next stage binary read took 1527664 us
[0007.758] Carveout took -1539345 us
[0007.762] CPU initialization took 2040129 us
[0007.766] Total time taken by TegraBoot 7850681 us
[0007.771] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):eca0c5e
NOTICE: BL31: Built : 00:21:27, Mar 13 2019
ERROR: Error initializing runtime service trusty_fast
[0007.893] RamCode = 0
[0007.897] LPDDR4 Training: Read DT: Number of tables = 2
[0007.902] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0007.915] EMC Training Successful
[0007.918] 408000 not found in DVFS table
[0007.925] RamCode = 0
[0007.928] DT Write: emc-table@204000 succeeded
[0007.933] DT Write: emc-table@1600000 succeeded
[0007.938] LPDDR4 Training: Write DT: Number of tables = 2
[0008.137]
[0008.138] Debug Init done
[0008.141] Marked DTB cacheable
[0008.144] Bootloader DTB loaded at 0x83000000
[0008.149] Marked DTB cacheable
[0008.151] Kernel DTB loaded at 0x83100000
[0008.155] DeviceTree Init done
[0008.168] Pinmux applied successfully
[0008.172] gicd_base: 0x50041000
[0008.175] gicc_base: 0x50042000
[0008.178] Interrupts Init done
[0008.183] Using base:0x60005090 & irq:208 for tick-timer
[0008.188] Using base:0x60005098 for delay-timer
[0008.192] platform_init_timer: DONE
[0008.196] Timer(tick) Init done
[0008.200] osc freq = 38400 khz
[0008.203]
[0008.204] welcome to cboot
[0008.207]
[0008.208] Cboot Version: 00.00.2018.01-t210-f76b856b
[0008.213] calling constructors
[0008.216] initializing heap
[0008.219] initializing threads
[0008.222] initializing timers
[0008.225] creating bootstrap completion thread
[0008.229] top of bootstrap2()
[0008.232] CPU: ARM Cortex A57
[0008.235] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0008.240] initializing platform
[0008.243] Scratch reg 37 & 271 initial value set..
[0008.249] cboot:secure-pmc present
[0008.252] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0008.257] ID LSB = 0x36, ID-CFI len = 194 bytes
[0008.261] Macronix QSPI chip present
[0008.265] SPI device register
[0008.268] init boot device
[0008.270] allocating memory for boot device(SPI)
[0008.275] registering boot device
[0008.284] sdmmc node status = okay
[0008.287] sdcard instance = 0
[0008.290] sdcard gpio handle 0x5d
[0008.293] sdcard gpio pin 0xc9
[0008.296] sdcard gpio flags 0x0
[0008.299] vmmc-supply 0x9d
[0008.302] Instance: 0
[0008.304] Allocating memory for context
[0008.308] enabling clock
[0008.310] sd card init
[0008.313] Check card present and stable
[0008.316] Send command 0
[0008.333] Send command 3
[0008.337] Set RCA for the card
[0008.340] Query card specific data by command 9
[0008.347] Parse CSD data
[0008.349] Send command 7
[0008.359] Calling sd device register
[0008.363] Init sdcard
[0008.365] Allocating memory for boot device
[0008.369] Registering user device
[0008.382] Enable APE clock
[0008.385] Un-powergate APE partition
[0008.388] of_register: registering tegra_udc to of_hal
[0008.393] of_register: registering tegra_udc to of_hal
[0008.399] of_register: registering inv20628-driver to of_hal
[0008.404] of_register: registering ads1015-driver to of_hal
[0008.410] of_register: registering lp8557-bl-driver to of_hal
[0008.415] of_register: registering bq2419x_charger to of_hal
[0008.421] of_register: registering cpc to of_hal
[0008.426] of_register: registering bq27441_fuel_gauge to of_hal
[0008.437] gpio framework initialized
[0008.441] of_register: registering tca9539_gpio to of_hal
[0008.446] of_register: registering tca9539_gpio to of_hal
[0008.451] of_register: registering i2c_bus_driver to of_hal
[0008.457] of_register: registering i2c_bus_driver to of_hal
[0008.462] of_register: registering i2c_bus_driver to of_hal
[0008.468] of_register: registering i2c_bus_driver to of_hal
[0008.473] pmic framework initialized
[0008.477] of_register: registering max77620_pmic to of_hal
[0008.482] regulator framework initialized
[0008.486] of_register: registering tps65132_bl_driver to of_hal
[0008.492] initializing target
[0008.498] gpio_driver_register: register 'tegra_gpio_driver' driver
[0008.507] fixed regulator driver initialized
[0008.524] initializing OF layer
[0008.527] NCK carveout not present
[0008.531] Skipping dts_overrides
[0008.535] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.551] I2C Bus Init done
[0008.553] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.563] I2C Bus Init done
[0008.566] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.576] I2C Bus Init done
[0008.579] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.589] I2C Bus Init done
[0008.592] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.602] I2C Bus Init done
[0008.605] of_children_init: Ops found for compatible string maxim,max77620
[0008.615] max77620_init using irq 118
[0008.620] register 'maxim,max77620' pmic
[0008.624] gpio_driver_register: register 'max77620-gpio' driver
This is my first try.
[0007.681] Secure Os AES-CMAC Verification Success!
[0007.710] NvTbootPackSdramParams: start.
[0007.722] Basic modules init took 5822313 us
[0007.754] Next stage binary read took 1527663 us
[0007.758] Carveout took -1539344 us
[0007.762] CPU initialization took 2040124 us
[0007.766] Total time taken by TegraBoot 7850756 us
[0007.934] DT Write: emc-table@1600000 succeeded
[0008.137]
[0008.152] Kernel DTB loaded at 0x83100000
[0008.203]
[0008.205] welcome to cboot
[0008.207]
[0008.294] sdcard gpio pin 0xc9
[0008.300] vmmc-supply 0x9d
[0008.416] of_register: registering bq2419x_charger to of_hal
[0008.474] pmic framework initialized
[0008.483] regulator framework initialized
[0008.564] I2C Bus Init done
And this is my second try.
