I have a problem about Jetson Nano developer kit. I flashed with sdkmanager in ubuntu 18.04.06 succesfully. But still stuck on NVIDIA logo.
Here is the logs:
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5499-d7000) (4
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 3f200000
[ 0.000000] OF: fdt: - c0000000 , 3ee00000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[0000.204] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.209] Processing in cold boot mode Bootloader 2
[0000.214] A02 Bootrom Patch rev = 1023
[0000.217] Power-up reason: software reset
[0000.221] No Battery Present
[0000.224] pmic max77620 reset reason
[0000.227] pmic max77620 NVERC : 0x0
[0000.230] RamCode = 1
[0000.233] Platform has DDR4 type RAM
[0000.236] max77620 disabling SD1 Remote Sense
[0000.240] Setting DDR voltage to 1125mv
[0000.244] Serial Number of Pmic Max77663: 0x170f68
[0000.252] Entering ramdump check
[0000.255] Get RamDumpCarveOut = 0x0
[0000.258] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.263] Last reboot was clean, booting normally!
[0000.268] Sdram initialization is successful
[0000.272] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.278] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.284] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.290] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.296] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.301] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.307] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.313] GSC3 Carveout Base=0x00000000bf300000 Size=0x00d00000
[0000.329] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.335] Platform-DebugCarveout: 0
[0000.339] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.344] Non secure mode, and RB not enabled.
[0000.349] *** Booting BFS0.
[0000.351] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.357] Read PT from (0:3)
[0000.372] Csd NumOfBlocks=0
[0000.411] PT crc32 and magic check passed.
[0000.415] Using BFS PT to query partitions
[0000.420] PT: Partition LNX NOT found !
[0000.423] *** Booting KFS0.
[0000.426] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.432] BoardID = 3448, SKU = 0x2
[0000.435] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.441] Read GPT from (0:3)
[0000.453] Using GPT Primary to query partitions
[0000.457] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.464] Loading Tboot-CPU binary
[0000.469] Verifying TBC in OdmNonSecureSBK mode
[0000.480] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.487] Bootloader downloaded successfully.
[0000.491] Downloaded Tboot-CPU binary to 0xa0000258
[0000.496] MAX77620_GPIO5 configured
[0000.500] CPU power rail is up
[0000.503] CPU clock enabled
[0000.506] Performing RAM repair
[0000.509] Updating A64 Warmreset Address to 0xa00002e9
[0000.514] BoardID = 3448, SKU = 0x2
[0000.518] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.524] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.530] Loading NvTbootBootloaderDTB
[0000.547] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.618] Bootloader DTB Load Address: 0x83000000
[0000.623] BoardID = 3448, SKU = 0x2
[0000.626] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.632] Loading NvTbootKernelDTB
[0000.648] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.720] Kernel DTB Load Address: 0x83100000
[0000.724] BoardID = 3448, SKU = 0x2
[0000.727] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.733] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.740] Loading cboot binary
[0000.751] Verifying EBT in OdmNonSecureSBK mode
[0000.793] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.800] Bootloader downloaded successfully.
[0000.804] BoardID = 3448, SKU = 0x2
[0000.807] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.813] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.819] PT: Partition NCT NOT found !
[0000.823] Warning: Find Partition via PT Failed
[0000.827] Next binary entry address: 0x92c00258
[0000.832] BoardId: 3448
[0000.837] Overriding pmu board id with proc board id
[0000.841] Display board id is not available
[0000.846] BoardID = 3448, SKU = 0x2
[0000.849] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.855] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.868] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.958] /bpmp deleted
[0000.960] SC7EntryFw header found loaded at 0xff700000
[0001.368] OVR2 PMIC
[0001.370] Bpmp FW successfully loaded
[0001.373] BoardID = 3448, SKU = 0x2
[0001.377] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.383] NvTbootFailControlDoFailover: No failover; Continuing …
[0001.390] WB0 init successfully at 0xff780000
[0001.394] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.399] Set NvDecSticky Bits
[0001.403] GSC2 address ff53fffc value c0edbbcc
[0001.409] GSC MC Settings done
[0001.412] BoardID = 3448, SKU = 0x2
[0001.415] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.422] TOS Image length 53680
[0001.425] Monitor size 53680
[0001.428] OS size 0
[0001.433] Secure Os AES-CMAC Verification Success!
[0001.438] TOS image cipher info: plaintext
[0001.441] Loading and Validation of Secure OS Successful
[0001.457] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.462] NvTbootPackSdramParams: start.
[0001.467] NvTbootPackSdramParams: done.
[0001.471] Tegraboot started after 132731 us
[0001.475] Basic modules init took 749405 us
[0001.479] Sec Bootdevice Read Time = 57 ms, Read Size = 3682 KB
[0001.485] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.490] Next stage binary read took 7389 us
[0001.494] Carveout took -34778 us
[0001.497] CPU initialization took 651822 us
[0001.501] Total time taken by TegraBoot 1373838 us
[0001.506] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):269577911
NOTICE: BL31: Built : 23:37:38, Nov 4 2024
ERROR: Error initializing runtime service trusty_fast
[0001.628] RamCode = 1
[0001.630] get_emc_table_offset: Can’t find emc-table node
[0001.635] LPDDR4 Training: Can’t find emc-table node
[0001.683]
[0001.684] Debug Init done
[0001.687] Marked DTB cacheable
[0001.690] Bootloader DTB loaded at 0x83000000
[0001.694] Marked DTB cacheable
[0001.697] Kernel DTB loaded at 0x83100000
[0001.701] DeviceTree Init done
[0001.716] Pinmux applied successfully
[0001.721] gicd_base: 0x50041000
[0001.724] gicc_base: 0x50042000
[0001.727] Interrupts Init done
[0001.732] Using base:0x60005090 & irq:208 for tick-timer
[0001.737] Using base:0x60005098 for delay-timer
[0001.742] platform_init_timer: DONE
[0001.745] Timer(tick) Init done
[0001.749] osc freq = 38400 khz
[0001.753]
[0001.754] Welcome to L4T Cboot
[0001.757]
[0001.758] Cboot Version: 00.00.2018.01-t210-acb23272
[0001.763] calling constructors
[0001.766] initializing heap
[0001.769] initializing threads
[0001.772] initializing timers
[0001.775] creating bootstrap completion thread
[0001.779] top of bootstrap2()
[0001.782] CPU: ARM Cortex A57
[0001.785] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.790] initializing platform
[0001.844] Config for emmc ddr50 mode completed
[0001.849] sdmmc bdev is already initialized
[0001.853] Enable APE clock
[0001.855] Un-powergate APE partition
[0001.859] of_register: registering tegra_udc to of_hal
[0001.864] of_register: registering inv20628-driver to of_hal
[0001.870] of_register: registering ads1015-driver to of_hal
[0001.875] of_register: registering lp8557-bl-driver to of_hal
[0001.881] of_register: registering bq2419x_charger to of_hal
[0001.886] of_register: registering bq27441_fuel_gauge to of_hal
[0001.899] gpio framework initialized
[0001.903] of_register: registering tca9539_gpio to of_hal
[0001.908] of_register: registering tca9539_gpio to of_hal
[0001.913] of_register: registering i2c_bus_driver to of_hal
[0001.919] of_register: registering i2c_bus_driver to of_hal
[0001.924] of_register: registering i2c_bus_driver to of_hal
[0001.930] pmic framework initialized
[0001.934] of_register: registering max77620_pmic to of_hal
[0001.939] regulator framework initialized
[0001.943] of_register: registering tps65132_bl_driver to of_hal
[0001.949] initializing target
[0001.955] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.964] board ID = D78, board SKU = 2
[0001.971] fixed regulator driver initialized
[0001.992] initializing OF layer
[0001.995] NCK carveout not present
[0001.998] Skipping dts_overrides
[0002.003] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.022] I2C Bus Init done
[0002.024] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.035] I2C Bus Init done
[0002.038] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.049] I2C Bus Init done
[0002.051] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.063] I2C Bus Init done
[0002.065] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.076] I2C Bus Init done
[0002.079] of_children_init: Ops found for compatible string maxim,max77620
[0002.090] max77620_init using irq 118
[0002.095] register ‘maxim,max77620’ pmic
[0002.099] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.106] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.117] I2C Bus Init done
[0002.121] NCK carveout not present
[0002.132] Find /i2c@7000c000’s alias i2c0
[0002.136] get eeprom at 1-a0, size 256, type 0
[0002.145] Find /i2c@7000c500’s alias i2c2
[0002.149] get eeprom at 3-a0, size 256, type 0
[0002.154] get eeprom at 3-ae, size 256, type 0
[0002.158] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.163] I2C slave not started
[0002.166] I2C write failed
[0002.169] Writing offset failed
[0002.172] eeprom_init: EEPROM read failed
[0002.176] pm_ids_update: eeprom init failed
[0002.180] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.210] pm_ids_update: The pm board id is 3448-0002-402
[0002.217] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0002.226] pm_ids_update: pm id update successful
[0002.230] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.260] eeprom_init: EEPROM incompatible version found
[0002.266] pm_ids_update: eeprom init failed
[0002.296] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.302] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.310] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.316] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.324] updating /chosen/nvidia,ethernet-mac node 3c:6d:66:45:4c:0e
[0002.331] Plugin Manager: Parse ODM data 0x000a4000
[0002.344] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0002.360] Find /i2c@7000c000’s alias i2c0
[0002.364] get eeprom at 1-a0, size 256, type 0
[0002.374] Find /i2c@7000c500’s alias i2c2
[0002.377] get eeprom at 3-a0, size 256, type 0
[0002.382] get eeprom at 3-ae, size 256, type 0
[0002.386] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.391] I2C slave not started
[0002.395] I2C write failed
[0002.397] Writing offset failed
[0002.400] eeprom_init: EEPROM read failed
[0002.404] pm_ids_update: eeprom init failed
[0002.408] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.438] pm_ids_update: The pm board id is 3448-0002-402
[0002.445] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0002.452] pm_ids_update: pm id update successful
[0002.456] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.486] eeprom_init: EEPROM incompatible version found
[0002.492] pm_ids_update: eeprom init failed
[0002.522] Add serial number:1421025050672 as DT property
[0002.530] Applying platform configs
[0002.537] platform-init is not present. Skipping
[0002.542] calling apps_init()
[0002.563] Found 17 GPT partitions in “sdmmc3_user”
[0002.568] Proceeding to Cold Boot
[0002.571] starting app android_boot_app
[0002.575] Device state: unlocked
[0002.578] display console init
[0002.587] could not find regulator
[0002.611] hdmi cable not connected
[0002.[0002.619] DT entry for leds-pwm not found
614] is_hdmi_needed: HDMI not connected, returning false
[0002.628] hdmi is not connected
[0002.631] sor0 is not supported
[0002.634] display_console_init: no valid display out_type
[0002.642] subnode volume_up is not found !
[0002.646] subnode back is not found !
[0002.650] subnode volume_down is not found !
[0002.654] subnode menu is not found !
[0002.658] Gpio keyboard init success
[0002.705] found decompressor handler: lz4-legacy
[0002.719] decompressing blob (type 1)…
[0002.784] display_resolution: No display init
[0002.788] Failed to retrieve display resolution
[0002.793] Could not load/initialize BMP blob…ignoring
[0002.798] -------> se_aes_verify_sbk_clear: 747
[0002.803] se_aes_verify_sbk_clear: Error
[0002.806] SE operation failed
[0002.809] bl_battery_charging: connected to external power supply
[0002.819] display_console_ioctl: No display init
[0002.824] switch_backlight failed
[0002.833] device_query_partition_size: failed to open partition sdmmc3_user:MS!
[0002.841] MSC Partition not found
[0002.850] device_query_partition_size: failed to open partition sdmmc3_user:US!
[0002.858] USP partition read failed!
[0002.861] blob_init: blob-partition USP header read failed
[0002.867] android_boot Unable to update recovery partition
[0002.872] kfs_getpartname: name = LNX
[0002.876] Loading kernel from LNX
[0002.967] load kernel from storage
[0002.977] decompressor handler not found
[0003.011] Successfully loaded kernel and ramdisk images
[0003.016] board ID = D78, board SKU = 2
[0003.021] display_resolution: No display init
[0003.025] Failed to retrieve display resolution
[0003.030] bmp blob is not loaded and initialized
[0003.034] Failed to display boot-logo
[0003.038] NCK carveout not present
[0003.041] Skipping dts_overrides
[0003.044] NCK carveout not present
[0003.055] Find /i2c@7000c000’s alias i2c0
[0003.059] get eeprom at 1-a0, size 256, type 0
[0003.069] Find /i2c@7000c500’s alias i2c2
[0003.073] get eeprom at 3-a0, size 256, type 0
[0003.077] get eeprom at 3-ae, size 256, type 0
[0003.082] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.087] I2C slave not started
[0003.090] I2C write failed
[0003.093] Writing offset failed
[0003.096] eeprom_init: EEPROM read failed
[0003.100] pm_ids_update: eeprom init failed
[0003.104] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.134] pm_ids_update: The pm board id is 3448-0002-402
[0003.141] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0003.150] pm_ids_update: pm id update successful
[0003.154] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.184] eeprom_init: EEPROM incompatible version found
[0003.189] pm_ids_update: eeprom init failed
[0003.220] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.225] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.234] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.239] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.248] updating /chosen/nvidia,ethernet-mac node 3c:6d:66:45:4c:0e
[0003.254] Plugin Manager: Parse ODM data 0x000a4000
[0003.268] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0003.276] Add serial number:1421025050672 as DT property
[0003.286] “bpmp” doesn’t exist, creating
[0003.292] Updated bpmp info to DTB
[0003.297] Updated initrd info to DTB
[0003.300] “proc-board” doesn’t exist, creating
[0003.306] Updated board info to DTB
[0003.309] “pmu-board” doesn’t exist, creating
[0003.315] Updated board info to DTB
[0003.319] “display-board” doesn’t exist, creating
[0003.325] Updated board info to DTB
[0003.328] “reset” doesn’t exist, creating
[0003.333] Updated reset info to DTB
[0003.336] display_console_ioctl: No display init
[0003.341] display_console_ioctl: No display init
[0003.345] display_console_ioctl: No display init
[0003.350] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype
[0003.384] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.390] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0003.406] Updated bootarg info to DTB
[0003.410] Adding uuid 0000000164410784140000000efe83c0 to DT
[0003.416] Adding eks info 0 to DT
[0003.422] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.428] Updated memory info to DTB
[0003.437] set vdd_core voltage to 1075 mv
[0003.441] setting ‘vdd-core’ regulator to 1075000 micro volts
[0003.447] Found secure-pmc; disable BPMP
U-Boot 2020.04-g904285e3a7 (Nov 04 2024 - 23:37:42 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 2 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC… *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
879 bytes read in 28 ms (30.3 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7160200 bytes read in 185 ms (36.9 MiB/s)
Retrieving file: /boot/Image
34707464 bytes read in 785 ms (42.2 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resiz
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317ce8d
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
