Hi!
I’m trying to capture image from a raspberry pi camera (CSI) and upload the image to my google drive automatically by using crontab.
My code works fine when I run it in terminal, and also work fine with just uploading an existing file to google drive by using crontab. However, it only failed when I tried to capture image using crontab or systemd.
I’ve been trying many methods, but it still not work at all.
Here is my python file:
import cv2
import time
from pydrive.auth import GoogleAuth
from pydrive.drive import GoogleDrive
gauth = GoogleAuth()
gauth.LoadCredentialsFile("mycreds.txt")
if gauth.credentials is None:
gauth.LocalWebserverAuth()
elif gauth.access_token_expired:
gauth.Refresh()
else:
gauth.Authorize()
gauth.SaveCredentialsFile("mycreds.txt")
def gstreamer_pipeline(
capture_width=1280,
capture_height=720,
display_width=1280,
display_height=720,
framerate=60,
flip_method=0,
return (
"nvarguscamerasrc ! "
"video/x-raw(memory:NVMM), "
"width=(int)%d, height=(int)%d, "
"format=(string)NV12, framerate=(fraction)%d/1 ! "
"nvvidconv flip-method=%d ! "
"video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
"videoconvert ! "
"video/x-raw, format=(string)BGR ! appsink"
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
def show_camera(new_path):
print(gstreamer_pipeline(flip_method=0))
cap = cv2.VideoCapture(gstreamer_pipeline(flip_method=0), cv2.CAP_GSTREAMER)
if cap.isOpened():
window_handle = cv2.namedWindow("CSI Camera", cv2.WINDOW_AUTOSIZE)
# Window
while cv2.getWindowProperty("CSI Camera", 0) >= 0:
ret_val, img = cap.read()
cv2.imwrite(new_path, img)
break
cap.release()
cv2.destroyAllWindows()
else:
print("Unable to open camera")
if __name__ == "__main__":
now_str = time.localtime()
new_path = str(now_str.tm_year) + str(now_str.tm_mon) + str(now_str.tm_mday) + str(now_str.tm_hour) + str(now_str.tm_min) + '.png'
upload_drive(new_path)
And this is my code in crontab -e
* * * * * cd desktop/image_temp && /usr/bin/python3.6 test_cam_path.py >> test_cam_path.out
And this is the content in test_cam.out:
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: PowerService: requested_clock_Hz=12096000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
CONSUMER: Done Success
WARNING Argus: 5 client objects still exist during shutdown:
547367618656 (0x7f78002760)
547372923680 (0x7f780016b0)
547372927056 (0x7f780028c0)
547372951104 (0x7f780043f0)
547372959144 (0x7f78004508)
Also I’ve check the syslog, here is part of the messege:
Jul 16 18:24:01 user-desktop CRON[8791]: (user) CMD (cd desktop/image_temp && /usr/bin/python3.6 test_cam_path.py >> test_cam_path.out)
Jul 16 18:24:02 user-desktop nvargus-daemon[6684]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== python3.6[8792]: Connection established (7F81CD61D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Jul 16 18:24:02 user-desktop nvargus-daemon[6684]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Jul 16 18:24:02 user-desktop nvargus-daemon[6684]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jul 16 18:24:02 user-desktop nvargus-daemon[6684]: ---- imager: No override file found. ----
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: LSC: LSC surface is not based on full res!
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: ---- imager: No override file found. ----
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 106)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: NvPclStartPlatformDrivers: Failed to start module drivers
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: NvPclOpen: PCL Open Failed. Error: 0xf
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 582)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 295)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 458)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: Acquiring SCF Camera device source via index 1 has failed. === python3.6[8792]: CameraProvider initialized (0x7f7c844740)LSC: LSC surface is not based on full res!
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: === python3.6[8792]: CameraProvider destroyed (0x7f7c844740)=== python3.6[8792]: WARNING: Cleaning up 1 outstanding requests...=== python3.6[8792]: WARNING: Cleaning up 1 outstanding streams...SCF: Error InvalidState: 4 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 305)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function ~EGLStreamProducer(), line 50)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: === python3.6[8792]: WARNING: Cleaning up 1 outstanding stream settings...=== python3.6[8792]: WARNING: Cleaning up 1 outstanding sessions...(NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:497) (in Mutex.cpp, function lock(), line 79)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: Buffer is not pending (in src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 501)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: (NvCameraUtils) Error InvalidState: Mutex has not been initialized (in Mutex.cpp, function unlock(), line 88)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBuffer(), line 486)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 447)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: (propagating from src/components/stages/BufferReturnStage.h, function doExecute(), line 43)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: SCF: Error BadParameter: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
Jul 16 18:24:03 user-desktop nvargus-daemon[6684]: (NvCameraUtils) Error InvalidState: Mutex not initialized (/dvs/git/dirty/git-master_linux/camera/core_scf/src/services/gl/EGLStreamProducer.cpp:399) (in Mutex.cpp, function lock(), line 79)
Jul 16 18:24:04 user-desktop systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=11/SEGV
Jul 16 18:24:04 user-desktop systemd[1]: nvargus-daemon.service: Failed with result 'signal'.
Jul 16 18:24:04 user-desktop CRON[8790]: (CRON) info (No MTA installed, discarding output)
Jul 16 18:24:04 user-desktop systemd[1]: nvargus-daemon.service: Service hold-off time over, scheduling restart.
Jul 16 18:24:04 user-desktop systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 2.
Jul 16 18:24:04 user-desktop systemd[1]: Stopped Argus daemon.
Jul 16 18:24:04 user-desktop systemd[1]: Started Argus daemon.
Jul 16 18:24:23 user-desktop bamfdaemon[7417]: bamf_matcher_set_starting_desktop_file: assertion 'desktop_file != NULL' failed
I would realy appreciate your help!!
