I have Jetson Nano dev kit(4GB) and Flir BFS-U3-16S2C-CS. https://www.flir.com/products/blackfly-s-usb3/?model=BFS-U3-16S2M-CS
I have installed all necessary packages to run camera on nano, but there is not enough power on usb port. When I run lsusb -v -d 1e10
on terminal I get following output.
Bus 002 Device 008: ID 1e10:4000 Point Grey Research, Inc.
Couldn’t open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.10
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 9
idVendor 0x1e10 Point Grey Research, Inc.
idProduct 0x4000
bcdDevice 0.00
iManufacturer 1
iProduct 2
iSerial 3
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 116
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 224mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionClass 239 Miscellaneous Device
bFunctionSubClass 5 USB3 Vision
bFunctionProtocol 0
iFunction 4
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 239 Miscellaneous Device
bInterfaceSubClass 5 USB3 Vision
bInterfaceProtocol 0
iInterface 0
** UNRECOGNIZED: 14 24 01 00 00 01 00 00 00 01 00 05 06 07 08 09 0a 0b 0c 0c
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 1
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
at that line > MaxPower 224mA shows me that there is not enough power for camera if I understand it correctly.
My question is can I somehow configure that output power to supply enough power for the camera?
