I’ve searched and followed instructions for installing and configure Wifi Bluetooth 8265 card.
Intel Dual Band Wireless-Ac 8265 w/Bluetooth 8265.NGWMG
The wifi works great, no issues.
The bluetooth having issues, although pairing is working, but unable to enable and stay on mode.
sudo apt update
sudo apt upgrade
sudo apt install pulseaudio pulseaudio-utils pavucontrol pulseaudio-module-bluetooth
sudo nano /etc/systemd/system/bluetooth.target.wants/bluetooth.service
and tried each of the following
ExecStart=/usr/lib/bluetooth/bluetoothd
ExecStart=/usr/lib/bluetooth/bluetoothd -d --noplugin=audio,avrcp
ExecStart=/usr/lib/bluetooth/bluetoothd -d --noplugin=audio,a2dp,avrcp
and reboot
The bluetooth mic and headset fails to enable and stay on
Verify Bluetooth is working
hcitool dev
If the Bluetooth adapter is working and available, you should see its address listed (each address is unique):
Devices:
hci0 18:##:##:##:##:##
Run bluetoothctl
Your Nano image should already have bluetoothctl installed.
At the command line, run the following:
bluetoothctl
You should see a response like this (substituting your devices address and hostname):
root@jet1:/home/jet1# bluetoothctl
[NEW] Controller 18:##:##:##:##:## jet1 [default]
[NEW] Device 00:##:##:##:##:## miniMic 1.0
Agent registered
[bluetooth]#
Show Bluetooth adapter info, from within the bluetoothctl app, you can check the status of your bluetooth adapter using the show command:
[bluetooth]# show
Controller 00:##:##:##:##:## (public)
Alias: jet1
Class: 0x00000000
Powered: yes
Discoverable: yes
Pairable: yes
UUID: Headset AG (00001112-0000-1000-8000-############)
UUID: Headset (00001108-0000-1000-8000-############)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-############)
UUID: PnP Information (00001200-0000-1000-8000-############)
UUID: Generic Access Profile (00001800-0000-1000-8000-############)
Modalias: usb:v1D6Bp0246d0530
Discovering: no
Any suggestions is greatly appreciated.
Thank you in-advance
Bob
