I have new Nvidia Jetson Nano board with Intel wireless 8265/8275 onboard, but the wifi is really, really bad - the power of detected signal is very low and the connection breaks off all the time. I need to use nano as an onboard computer for a small robotic system, but for now the only possibilty to work remotly is by using ethernet cable (so that’ s not the most flexible option).
I checked if the card is detected by using
lshw -C network
*-network
description: Wireless interface
product: Wireless 8265 / 8275
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlan0
version: 50
serial: 34:13:e8:63:61:6d
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=4.9.201-tegra firmware=22.391740.0 ip=192.168.1.91 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:408 memory:13000000-13001fff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 15
serial: 00:04:4b:ec:b7:dc
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.045.08-NAPI duplex=full ip=192.168.1.90 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:406 ioport:1000(size=256) memory:13104000-13104fff memory:13100000-13103fff
*-network DISABLED
physical id: 1
logical name: dummy0
serial: 12:55:64:11:ba:7c
capabilities: ethernet physical
configuration: broadcast=yes driver=dummy driverversion=1.0
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Then, I did, because all forums say it can be du to power:
sudo iw dev wlan0 set power_save off
iw dev wlan0 get power_save off
Power save: off
(but after restarting I had to do it again)
It’s not router since I checked two of them already and the hotspot from my phone. The wifi works pretty nice on my laptop and my phone.
What else can I do?
PS I’m using micro-usb as power supply (i thought maybe the powers it too low, but i would be weird, right?).
