Jetson Nano Wifi M2.2 module - replacement for AC8265?
I am using a Jetson Nano with custom Base Board and an M2. WiFi module.
The Module in use is is the intel AC 8265NGW, which is the only device listed in the “Supported Component List” for Jetson Nano.
Unfortunately, this module seems to be discontinued and is no longer available.
Does anybody know a replacement that works with Jetson Nano? Will the intel AX200/AX201 modules work?
The AX200 should work, you can refer to Jetson Nano enable WiFi intel AX200 then shutdown - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
