I installed the wifi module 8260 ngw on the jetson nano.
Can not boot.
If you have the same symptoms, share the solution
Thank you.
It is a known issue that 8260 would cause i2c error on Jetson Nano and Jetson Xavier. After investigation, this is somehow a Intel design problem. (Maybe not a problem on Intel platform)
