I was also noticing slow wifi speeds with the EW-7811UN.
Following the steps in the patch to install 8192cu driver seemed to work for me. I am not sure the simple blacklist of rtl8192cu worked for me. I tried that first and iwconfig showed:
wlan0 IEEE 802.11 ESSID:“Occamsrouter”
Mode:Managed Frequency:2.412 GHz Access Point: 2C:7E:81:F3:99:2E
Bit Rate=1 Mb/s Tx-Power=30 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Power Management:off
Link Quality=54/70 Signal level=-56 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:7 Missed beacon:0
After installing the 8192cu patch:
wlan0 IEEE 802.11bgn ESSID:“Occamsrouter” Nickname:“WIFI@REALTEK”
Bit Rate:72.2 Mb/s Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Link Quality=99/100 Signal level=87/100 Noise level=0/100
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
Bit rate seems to have jumped from 1 to 72 Mb/s. Thanks for the help.
disabling the rtl8192cu driver (and using the rtl8xxxu driver instead) limited the bit rate to 1 Mb/s
installing the fixed 8192cu driver allowed me to connect with a stable connection at 72.2 Mb/s
The installation instructions for the fixed driver (GitHub - pvaret/rtl8192cu-fixes: Realtek 8192 chipset driver, ported to kernel 3.11.) disable both the native rtl8192cu and rtl8xxxu drivers - so if you are following the installation instructions, don’t skip that step if you’ve already disabled the rtl8192cu drivers using the instructions in the thread - you’ll probably end up using the rtl8xxxu driver rather than the fixed driver (this is a mistake that I made).
I just put the Nano on a shelf, seems I don’t have any USB WiFi devices that it likes, meanwhile they all work with a Raspberry PI… Come on, add a few of the common drivers please, I don’t have the time to spend compiling a new kernel nor should I have to. Yes a 8265 and antennas are in a slow truck somewhere… The USB wifi: lsmod r8188eu is seen as cfg80211 - I killed my hardwired network for a Verizon Hotspot
UPDATE: Late that evening the power went down and when it restarted I had WiFi, don’t know how but it worked, kind of slowly but working.
The Intel card and antennas arrived this morning, WAY better speed plus Bluetooth.
I had the same problem of intermittent connection using an rtl8192cu based wifi usb dongle. I did
echo "blacklist rtl8192cu" | sudo tee -a /etc/modprobe.d/blacklist.conf
echo options rtl8xxxu ht40_2g=1 dma_aggregation=1 | sudo tee /etc/modprobe.d/rtl8xxxu.conf
FInally rebooted.
After reboot the USB dongle has been working normally for 1hr.
Looking at the ‘Connection information’ in the wifi symbol in the right upper corner, I see the driver displayed is ‘rtl8xxxu’…
I also get
nvidia@nvidia-desktop:~$ lsusb
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
wlan0 IEEE 802.11 ESSID:"RIS_2G"
Mode:Managed Frequency:2.457 GHz Access Point: EC:08:6B:21:C1:A0
Bit Rate=1 Mb/s Tx-Power=20 dBm
Link Quality=66/70 Signal level=-44 dBm
Tx excessive retries:0 Invalid misc:3467 Missed beacon:0
I have problems with the Edimax Wifi USB stick, too.
When I boot the Nano with only the micro USB (5V 2.5A Raspberry supply) connected, the Wifi doesn’t start.
It only starts, when I connect the LAN cable and log into Nano (via Ubuntu Desktop or SHH). After that the Nano connects to my Wifi network and I can SSH into it from remote to the wlan ip. Via ifconfig I then find two ip adresses (eth0 and wlan0).
I tried to set the “Turn off Wifi to save power” function to “off” in the Gnome Settings (from remote desktop connection), but when I reopen the settings window it is back to “on”.
I tried the terminal command: sudo iw dev wlan0 set power_save off
But when I plugged out the LAN cabel and reboot the Nano, I can`t find the Nano in my Wifi network.
Sure, that can be worth trying - although it sounds like your issue is different from the others in this post. The original issue from this post was that the wifi disconnects after a period of time (not really related to reboot), but you could still try these patches to see if it helps. If the issue persists, I would recommend trying a fresh SD card image to see if it may be related to trying the multiple patches and configuration issues. You should be able to initially connect (even after reboots) with the vanilla driver - the symptom is it disconnects after a period of time.
I think there was something wrong with the first installation. The install process was very fast this time, last time, it hangs for 10 or 15 minutes at on step, but not so this time.
Perhaps it was helpful, that the Wifi dongle was sticked into the Nano, before I began with the installation…
OK great, good to hear Lars. Now if you notice the wifi disconnecting after a period of time, you can try the patches from this thread. We hope to include that in the next JetPack for the Edimax adapters.
make defconfig-iwlwifi-public
sed -i 's/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/' .config
make -j4
sudo make install
sudo make install
Building modules, stage 2.
MODPOST 6 modules
INSTALL /home/nvidia/backport-iwlwifi/compat/compat.ko
INSTALL /home/nvidia/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
INSTALL /home/nvidia/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.ko
INSTALL /home/nvidia/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/xvt/iwlxvt.ko
INSTALL /home/nvidia/backport-iwlwifi/net/mac80211/mac80211.ko
INSTALL /home/nvidia/backport-iwlwifi/net/wireless/cfg80211.ko
DEPMOD 4.9.140-tegra
depmod will prefer updates/ over kernel/ -- OK!
Note:
Note:
You may or may not need to update your initramfs, you should if
any of the modules installed are part of your initramfs. To add
support for your distribution to do this automatically send a
patch against "update-initramfs.sh". If your distribution does not
require this send a patch with the '/usr/bin/lsb_release -i -s'
("Ubuntu") tag for your distribution to avoid this warning.
Your backported driver modules should be installed now.
Reboot.
rebooting
and nothing
modprobe iwlwifi
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
