Jetson Nano will no longer boot
I have been using my jetson nano for a few months now and it will no longer boot.
This is the output it prints before hanging:
Notes:
  • I am using a barrel jack connector (5V/4A) to power the device (have been using this for months).
  • I only had an HDMI cable connected to a monitor (have been using this for months)
  • Things I remember doing before shutting down last time:
    • Adding a line to my .bashrc
    • Commenting out something I added earlier to my /etc/resolv.conf
Any help would be appreciated!
Press ctrl+alt+F1~F6 when you hit this and see if it goes to console mode.
If so, could you dump the syslog (/var/log/syslog)?
This allowed me to access a terminal and fix my .bashrc
Everything appears to be working now - thanks!
Could you tell us what was added to your bashrc?
I added the following 2 lines:
sudo ip ad add 10.0.0.20/24 dev eth0
When I pressed ctrl+alt+F1~F6 I encountered a popup that said “Error found when loading /home/jetson/.profile”. I then clicked OK, opened up a terminal, and removed those lines from the .bashrc.
