Hello, I would like to ask how Jetson Nano can solve the problem with the camera of Flir (model: BFS-U3-04S2C-CS) successfully detected.
Currently I use the v4l2-ctl --info --list-devices command, but there is /dev/video under my path. How can I solve it?
Moving into Jetson Nano forum.
Do you mean there is no /dev/video#?
yes
You need to check the log from the driver to check why the probe failed. Possible the i2c failed ack I guess.
