Jetson nano wont boot, used multiple micro sd cards and different versions of the Jetson nano image zip and multiple different SD card flashers and tried both hdmi and headless mode to boot up the board. First time it booted up as expected using HDMI and went through setup until setting wifi when screen said fatal error and shut down and now will no longer boot up even though LED lights up.
I would suggest you can try this
And also buy a cable to help dump log.
