My new nano won’t power up at all. I connect the power supply and get the green light but my monitor never gets a signal …
Configuration:
Jetson Nano with fan mounted on top
Adafruit 4A @ 5V power supply with jumper to disable USB power (actually I have tried two separate 4A/5V power supplies)
USB mouse / keyboard attached
Freshly flashed microSD card inserted and secure
CAT6 cable to network attached
Display port cable to monitor connected
Any ideas? It was working fine until I re-flashed the microSD. I have re-flashed several times since … notta
Well I bought this cable, plugged it in and the drivers loaded successfully:
JBtek Windows 8 Supported Debug Cable USB Programming USB to TTL Serial Cable
Then I found a good terminal app called Tera Term. I set it up as follows:
Start Tera Term
Click the Serial radio button and select the COM port labeled “Prolific USB-to-Serial Comm Port”
Click the OK button
Click the Setup tab in the Tera Term VT window and select Serial Port
Change the Baud Rate to 115200 and click the OK button (Other parameters should be as follows by default: Data: 8 bit; Parity: none; Stop: 1 bit; Flow control: none)
Click the Setup tab in the Tera Term VT window and select General…
In the Tera Term General Setup dialog box, change the Language from UTF-8 to English
I printed the RMA form and shipped the nano 16 days ago and I have not heard anything since. There seems to be no way for me to check the RMA status. The online form for updating info on the case does not update. How can I find out about the RMA status? I’ve been without use of the unit over 3 weeks now …
