Tried on off etc, unit only powers on automatically, when power supply in, unable to get to boot or show nvidia splash, connecting usb to usb 2 port and to pc doesnt notify any sound of a device being connected to windows…
Tried switching to usb power, again green light comes on, worked for bit, then consistently no matter if use 4a or usb power, green light on but no hdmi signal or sign of boot, or power to usb devices like keyboard, and if leave on the heatsink doesnt heat up…
Had since about June 2021, tried reflashing card… doesnt seem to do much…
and card seems readable , what did notice though was reading as infinite partitions almost in windows before formatting again… not sure if that is normal
Power supply on barrel reads 5.2v consistent still…
Have been unemployed as IT and Media and AV tech in country, so replacement is a challenge, was just using to play media in browser really until came up with a solid idea that no one else in world doing whereas to become relevant again in changing times…
Not sure if anyone experienced the same and have a magic fix?
Some forums say bridge reset and rec pin, I bridged rec and gnd… now get apx device in windows, but no driver attached to that apx device… where to from there if anything should do in rec?
Is it possible to probe the power on sequence as listed in Design Guide? That may help. Also you can use a DC supply to read the current to check if any component shorted to GND which will cause high current.
But took an extra look while trying to find references and spot resistor values as if the screen printed…either missing it or the layout is different… then observed module pins attached to the female connector… spec of dirt I thought was a bent copper gold pin… and in tern say was silver solder pins, not copper-gold visible… and the orange spec was between two pins… and stuck… blew enough, tested power… say text… giving up at a win for now… to savor… thanks for options if this solves that… though this could be listed as a symptom if when no flash, unsure if no flash will work now… must test… or more simply maybe no boot… or just luck…
