I try to flash NX which I use with Jetson Nano Board. Here I get this error while flashing
Jetson NX jetpack 4.4.1 flashing with SDK causes error :
14:32:53 ERROR: Flash Jetson Xavier NX: Board ID(3668) version(200) sku(0001) revision(G.0)
14:32:53 ERROR: Flash Jetson Xavier NX: 1+0 records in
14:35:00 ERROR: Flash Jetson Xavier NX: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP.sh; [error]: 1+0 records in
14:35:00 ERROR: Flash Jetson Xavier NX: command terminated with error
the log is below
SDKM_logs_JetPack_4.4.1_Linux_for_Jetson_Xavier_NX_2021-03-16_14-28-47.zip (307.4 KB)
I use SDK to download and flash the device.
I assume i put the device in to Recovery Mode
My host device has Ubuntu 18.04.5 LTS
thank you in advance
