hi.
our product with jetson NX,can not start up.We test the singal POWN_IN POWR_EN is ok.but the system cannot work.repeatly the same information.following:
ump :[2021-07-16 09:05:56.116]
0000000000011111111110111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000[2021-07-16 09:05:56.128]
??[2021-07-16 09:05:56.155]
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.[2021-07-16 09:05:56.163]
[0000.033] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)[2021-07-16 09:05:56.168]
[0000.038] I> Boot-mode: Coldboot[2021-07-16 09:05:56.171]
[0000.041] I> Chip revision : A02P[2021-07-16 09:05:56.173]
[0000.044] I> Bootrom patch version : 15 (correctly patched)[2021-07-16 09:05:56.179]
[0000.049] I> ATE fuse revision : 0x200[2021-07-16 09:05:56.181]
[0000.053] I> Ram repair fuse : 0x0[2021-07-16 09:05:56.184]
[0000.056] I> Ram Code : 0x0[2021-07-16 09:05:56.187]
[0000.058] I> rst_source : 0xb[2021-07-16 09:05:56.189]
[0000.061] I> rst_level : 0x1[2021-07-16 09:05:56.194]
[0000.065] I> Boot-device: QSPI[2021-07-16 09:05:56.196]
[0000.067] I> Qspi flash params source = brbct[2021-07-16 09:05:56.202]
[0000.071] I> Qspi using bpmp-dma[2021-07-16 09:05:56.204]
[0000.074] I> Qspi clock source : pllp[2021-07-16 09:05:56.207]
[0000.078] I> QSPI Flash Size = 32 MB[2021-07-16 09:05:56.209]
[0000.081] I> Qspi initialized successfully[2021-07-16 09:05:56.217]
[0000.085] E> LOADER: Failed to verify SMD.[2021-07-16 09:05:56.219]
[0000.089] I> Primary SMD copy is invalid, try with secondary copy…[2021-07-16 09:05:56.226]
[0000.095] E> LOADER: Failed to verify SMD.[2021-07-16 09:05:56.237]
[0000.099] E> LOADER: Failed to verify SMD & SMD_b.[2021-07-16 09:05:56.237]
[0000.103] E> Error: SMD: Load failed[2021-07-16 09:05:56.238]
[0000.107] E> Load SMD failed[2021-07-16 09:05:56.241]
[0000.109] E> LOADER: Failed to get slot for boot chain from SMD.[2021-07-16 09:05:56.247]
[0000.115] E> LOADER: Failed to get storage info for binary 0 from loader.[2021-07-16 09:05:56.250]
[0000.121] E> LOADER: Failed to get info for binary 0 from loader.[2021-07-16 09:05:56.256]
[0000.127] C> LOADER: Could not read binary 0.[2021-07-16 09:05:56.261]
[0000.131] C> Fail to load mb1-bct bin[2021-07-16 09:05:56.264]
[0000.134] E> Task 24 failed (err: 0x1d1d1318)[2021-07-16 09:05:56.266]
[0000.138] E> Top caller module: LOADER, error module: LOADER, reason: 0x18, aux_info: 0x13[2021-07-16 09:05:56.275]
[0000.146] I> MB1(1.5.1.3-t194-41334769-d2a21c57) BIT boot status dump :[2021-07-16 09:05:56.283]
0000000000011111111110111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000[2021-07-16 09:05:56.305]
??[2021-07-16 09:05:56.332]
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.[2021-07-16 09:05:56.350]
[0000.033] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)[2021-07-16 09:05:56.350]
[0000.038] I> Boot-mode: Coldboot[2021-07-16 09:05:56.353]
[0000.041] I> Chip revision : A02P[2021-07-16 09:05:56.353]
[0000.044] I> Bootrom patch version : 15 (correctly patched)[2021-07-16 09:05:56.357]
