I downloaded the sd card image(nv-jetson-nx-sd-card-image-r32.4.2.zip)
However, it is printed as damaged.
Is it my only problem?
How can I get the right image?
Could you share the log with us?
Damage is output when decompressing in windows.
So I select a compressed file right from the Etcher program.
This action was repeated several times.
Etcher log.
Error opening image
Something went wrong while opening nv-jetson-nx-sd-card-image-r32.4.2.zip
Error: end of central directory record signature not found.
I downloaded the same file a few days ago and used it without any problems. I did however, unpack the zip file first and selected the sd-blob.img in Etcher.
I got the correct file from a co-worker.
Fortunately it works well.
However, I’m still not sure why the file I downloaded is not working…
I’ll finish anyway.
