Is there a preferred connector for the NX Xavier SOM for integrating into a larger board, or will any 260 pos SODIMM connector work?
Related topics
| Jetson NX/TX2/Nano SODIMM pinout compatibility with Orin | 2 | 2488 | October 18, 2021 | |
| Ethernet connector selection Jetson Xavier NX based carrier board design | 2 | 357 | January 3, 2023 | |
| Can i use the carrier board which comes with jetson xav nx dev kit with the jetson xavier nx som module (P3668 model) | 2 | 229 | February 28, 2024 | |
| 900-83668-0000-000 | Jetson Xavier NX Module - Connect to PCI | 2 | 400 | October 18, 2021 | |
| Connecting Micro SD to Jetson Xavier NX | 2 | 367 | July 3, 2023 | |
| Jetson SOM Xavier NX Cable extension | 2 | 96 | August 21, 2024 | |
| Is it possible to connect the Xavier NX to the dev kit carrier board through riser cables? | 2 | 378 | October 18, 2021 | |
| Xavier NX board with Nano Developer Kit board | 45 | 4802 | May 2, 2023 | |
| NVIDIA announces Jetson Xavier NX | 52 | 8612 | May 18, 2020 | |
| Connect 2 Jetson Xavier NX SOMs over a custom board | 9 | 812 | February 21, 2023 |
