Jetson opencv to rtsp stream
I’m stuck trying to stream video from opencv python to rtsp
In python I’ve the following code to capture from the camera and convert to h265
framerate = 25.0
out = cv2.VideoWriter("appsrc ! videoconvert ! omxh265enc preset-level=3 ! rtph265pay name=pay0 pt=96 ! udpsink host=127.0.0.1 port=5555", 0, framerate, (624, 352))
In the command line I start the test-launch app with the following line
/test-launch --gst-debug-level 3 "udpsrc port=5555 ! application/x-rtp ! rtph265depay ! rtph265pay name=pay0 pt=96"
But when I open vlc rtsp://localhost:8554/test I cannot view the video and get this warning
0:00:15.644267750 18988   0x7f90005680 FIXME           rtph265depay gstrtph265depay.c:1278:gst_rtp_h265_depay_process:<rtph265depay0> Assuming DONL field is not present
0:00:15.644317959 18988   0x7f90005680 FIXME           rtph265depay gstrtph265depay.c:1278:gst_rtp_h265_depay_process:<rtph265depay0> Assuming DONL field is not present
0:00:15.644370304 18988   0x7f90005680 FIXME           rtph265depay gstrtph265depay.c:1278:gst_rtp_h265_depay_process:<rtph265depay0> Assuming DONL field is not present
0:00:15.644417753 18988   0x7f90005680 FIXME           rtph265depay gstrtph265depay.c:1278:gst_rtp_h265_depay_process:<rtph265depay0> Assuming DONL field is not present
0:00:15.644468483 18988   0x7f90005680 FIXME           rtph265depay gstrtph265depay.c:1278:gst_rtp_h265_depay_process:<rtph265depay0> Assuming DONL field is not present
0:00:15.644519525 18988   0x7f90005680 FIXME           rtph265depay gstrtph265depay.c:1278:gst_rtp_h265_depay_process:<rtph265depay0> Assuming DONL field is not present
Any tip?
