I’m using a Jetson Orin AGX for my mobile robot platform. Initially i used the original usb-c power cable to power up the board. Now I want to put this into a mobile platform and power it using a battery.
I’m using the XP-1 as the power supply of the jetson [ Link ] . I tried to use the standard usb to type c cable to power up jetson but it does not work. Not even the led light turned on.
In this power supply I have USB, USB-C and EC5 outputs. What should i do to power up the Jetson?
Please check with the XP-1/power supply vendor on which output to use. The USB2 port power maybe limited to say15W?
can i use the DC output of the XP-1 to power up the jetson via dc jack ?
Please refer to the Orin Nano data sheet. Log in | NVIDIA Developer
You will need to check/verify if XP-1 meets these requirements. If it does then you could give it a try.
Thanks for the response. Mine is Orin AGX. I checked xp-1 dc output. it gives me 16.5V out when I measure it using a multimeter.
My mistake. Topic is filed against Jetson Nano, however thanks for confirming you are using AGX Orin. You can refer to AGX Orin data sheet then Log in | NVIDIA Developer
16.5V@what current rating? Wattage/AH rating of the XP-1/battery?
Thank you. This helped and i managed to power up with DC supply.
