I have a custom carrier board that has the Jetson Orin AGX Industrial module installed on it. I am trying to boot JetPack 6.2.1 Linux on the Orin with the RGMII interface between the EQOS MAC and a TI DP83869HM PHY (on the carrier card). The error from the serial port is:
[ 14.612967] nvethernet 2310000.ethernet: failed to connect PHY
[ 14.612984] net eth0: ether_open: Cannot attach to PHY (error: -19)
A google search on this error suggested I check several items.
Pinmux:
These are the pinmux settings in the Excel file that I am using:
Reset and Interrupt GPIOS:
RGMII and MDIO:
The resulting three output files were copied to the Linux build machine and put into the paths referenced by my custom board conf file.
Device Tree section I am using (PHY ID is confirmed as ID 3 on hardware):
bus@0 {
/* Removed for brevity */
ethernet@2310000 {
/* Setting status = "okay" enables the device */
status = "okay";
/* nvidia,tegra234-eqos refers to the NVIDIA Orin */
/* AGX processor. The -eqos refers to the 1Gb */
/* Ethernet MAC */
/* eqos stands for Ethernet Quality of Service */
/* snps refers to synopsis, with dwc-qos-ethernet */
/* being the base of the 1Gb Ethernet IP */
/* Having both compatible statements is required */
compatible = "nvidia,tegra234-eqos","snps,dwc-qos-ethernet";
/* Phy Handle defined below */
phy-handle = <&ti_dp83869_phy>;
/* Using the RGMII interface so specify the */
/* rgmii-id mode */
/* rgmii-id specifies that the PHY controls the */
/* timing delays instead of the MAC */
/* NVIDIA support confirmed that rgmii MAC does */
/* not support Rx/TX delays internally and they */
/* must be supplied by a PHY. Therfore, rgmii, */
/* rgmii-rxid and rgmii-txid will not work as */
/* phy-mode entries */
phy-mode = "rgmii-id";
/* This maps to the GPIO PG05 pin where the */
/* ENET_RST_N signal is connected */
nvidia,phy-reset-gpio = <&gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
/* mac-addr-idx is used to index into an array in */
/* the I2C eeprom on board the GPU module */
/* Kernel throws error on invalid index right now */
/* so the nvidia,ether-max* entries are used below*/
nvidia,mac-addr-idx = <0>;
nvidia,max-platform-mtu = <8000>;
nvidia,pause_frames = <0>;
/* Some sources online say this is required - set */
/* it to the same as nvidia,ether-mac */
local-mac-adress = [48 80 2D 68 C9 1C];
nvidia,ether-mac = "48:80:2D:68:C9:1C";
nvidia,ether-mac0 = "48:80:2D:68:C9:1C";
nvidia,ether-mac1 = "48:80:2D:68:C9:1D";
nvidia,ether-mac2 = "48:80:2D:68:C9:1E";
nvidia,ether-mac3 = "48:80:2D:68:C9:1F";
nvidia,ether-mac4 = "48:80:2D:68:C9:20";
nvidia,ether-mac5 = "48:80:2D:68:C9:21";
nvidia,ether-mac6 = "48:80:2D:68:C9:22";
nvidia,ether-mac7 = "48:80:2D:68:C9:23";
nvidia,ether-mac8 = "48:80:2D:68:C9:24";
nvidia,ether-mac9 = "48:80:2D:68:C9:25";
/* Not sure if these two lines are helping or */
/* hurting currently */
clock-names = "slave_bus","master_bus","rx","tx","ptp_ref";
reset-names = "eqos";
/* MDIO section describes everything from singals */
/* to devices on this bus */
mdio {
/* Set compatibility to nvidia,eqos-mdio and */
/* synopsis dwc-qos-ethernet-mdio */
compatible = "nvidia,eqos-mdio", "snps,dwc-qos-ethernet-mdio";
/* These next two lines are required */
#address-cells = <1>;
#size-cells = <0>;
/* Define the TI DP83869HM PHY settings - */
/* phy@3 specifices Device ID 03 */
ti_dp83869_phy: ethernet-phy@3 {
/* Set the device to active */
status="okay";
/* Set compatible so that it finds the TI */
/* DP83869 device driver - must be enabled*/
/* in kernel */
compatible = "ti,dp83869";
device-type = "ethernet-phy";
/* reg = must match the PHY device ID */
/* above or 3 */
reg = <0x3>;
/* Set both TX/RX FIFO depths to 4 Bytes */
tx-fifo-depth = <DP83869_PHYCR_FIFO_DEPTH_4_B_NIB>;
rx-fifo-depth = <DP83869_PHYCR_FIFO_DEPTH_4_B_NIB>;
/* Make sure we are in RGMII Copper mode */
ti,op-mode = <DP83869_RGMII_COPPER_ETHERNET>;
ti,max-output-impedance;
ti,clk-output-sel = <DP83869_CLK_O_SEL_CHN_A_RCLK>;
rx-internal-delay-ps = <2000>;
tx-internal-delay-ps = <2000>;
nvidia,phy-rst-pdelay-msec = <224>; /* msec */
nvidia,phy-rst-duration-usec = <10000>; /* usec */
/* Set the Interrupt pin up as a gpio pin */
/* and use PG04 - maps to ENET_INT */
interrupt-parent = <&gpio>;
interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
Currently trying to install the mdio-tool into the Linux image to read the PHY registers.
I do not have wires on the MDIO lines currently but could install them if required.
I would greatly appreciate help in figuring out why I can’t talk to the PHY from the EQOS MAC.
